Whirpool inspiration Hi, this washing machina stopped working, as the drum does not want to turn. It appears as something around the drum got loos. What to do.
    Scholar:
  • 74 Answers
Hiya... unless your machine is a direct drive it sounds like your drive belt has snapped! Could possibly have stretched.. either way you need to replace!
Regards Faggly
Posted on Mar 20, 2008
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Machine is filling with water but the drum wont turn or spin
MOST LIKELY THE MOTOR IS SHOT OR THE BELT AROUND THE DRUM CAME OFF THE DRUM
Feb 06, 2013 | Washing Machines
Spin no squeeze
Drain it, unhook it and lay it down, check underneath for broken springs on the drum to the frame
Sep 25, 2012 | Whirlpool Washing Machines
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
Whirlpool washer drive problem
ck coupling between motor and transmission ..whirpool part # 285753a
Nov 21, 2008 | Washing Machines
Whirpool washing machine
The FP code just means that your filter is clogged or has a hair doo-dad or something in it that needs to come out. There are Guys on YouTube that will show you how to do that, step by step, just google Whirlpool AWM8103/1 fault codes to see them. Tip* Have a Large but Shallow pan or container of some sort ready to catch the water that the filter will be holding in it's line because it will come rushing out when you open the filter housing! Towels will be useful. Merry Christmas!
Dec 03, 2017 | Whirlpool AWM8103/1 Front Load Washer
Washin Machine Spinning Problem
The main tub bearing is stuffed, thus the noise. The spindle becomes loose and the belt rides off. Bearings can be replaced.
Hope that helps.
Sep 07, 2008 | Hoover AL130 Front Load Washer
Whirpool top loader unbalanced spin cycle
First change the springs - both the leveling and suspension. You may also need to change a few other parts on the brake and drive tube including the thrust ring. But replace the springs and let see what happens.
Post your results . Remember to rate this solution
Regards
Jul 27, 2008 | Whirlpool LSB6200KQ Top Load Washer
Kenmore Washer Spin Issue - Need help troubleshooting
Check the coils on the wig-gag. Its a couple of bars that engage the spin drive or the wash drive. If you look at the machine when its running you will see it moving back and forth, hence the name. If the coil engages the spin cam, but it still will not spin then the tranny is your next culprit.
Jan 04, 2008 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
