Question about Whirlpool Duet GHW9150P Front Load Washer
Door Error My Samsung big wash will not open the door when i press the electronic door button, it releases when i pull the cord release cable, when the door is closed the machine displays "door" and will start.
    Scholar:
  • 74 Answers
Hiya... how long are you waiting? there is a timer door delay.. on nearly all washers now... usually around 2-5 mins!... Wait a few mins and see if this cures the prob.
Regards Faggly
Posted on Mar 20, 2008
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Bickley
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
My gas flap is stuck closed. We had to pry it open yesterday to fill the tank. 2 months ago the same thing happened, but it has worked since then.
If you have fuel door release cable & door is open, verify that cable moves in & out when you activate it. If yes you can adjust tab that it rests on so it will release properly. Just bend tab slightly inward at first, till it releases correctly.
Jun 14, 2010 | 2002 Volkswagen Passat
Waste ink absorber almost full
Hi there
You will need at some time to clean out the ink out of the pads, or it will make a big mess
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
All the Best Pineworks
Mar 11, 2010 | Canon Pixma iP6600D InkJet Photo Printer
Fuel door does not open
I can't promise that this will apply to your car, but in my Audi, there is a manual release cable in the trunk, and your car may have one too. Go into the trunk, pull back the trunk lining on the side where the gas filler door is and look for a pull cord. Often the European cars have this feature since their gas doors are unlatched electronically, and this serves as a backup in case the electronic release fails. Take a look and see if you have this feature - I'd almost be surprised if you don't.
Jan 18, 2010 | 2000 Volvo S80
MAYTAG NEPTUNE DOOR LOCKED WILL NOT OPEN!
The comment posted 14 may 2009 it what helped me. DO NOT PRY OPEN the door. Find the release cord inside the soap dispenser,,,you may have to remove the 4 screws and lift it from the washer like i did. I had to lean into the door and pull the cord to release the lock. It was not a system error. The washer was over loaded and although the door was closed and locked...the load pushed the door enough to indicate that it was open and would not wash. After opening the door, rearranging the load and removing some, the door closed and latched locked and was able to continue with the wash. DO NOT PRY OPEN,,,use the cord release first,,,this worked for me.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Getting FL error with Beeping and can't open door now
This just happened to us.
There is a release cord/string that can be accessed from the front of the soap/softner dispenser.
Remove the trays in the dispenser and reach towards the front of the machine. Find the end of the nylon line. Grasp firmly and pull to your left if your are facing the maching. I had to pull a few time before the door opened because I couldn't get a good grip and I didn't know how hard to pull without breaking the string. It might help to push in on the door at the same time, to realease.
I have to say, I was really surprized to find the nylon line as I was looking for a way to remove the tray and try reaching to see if there was a latch release.
Apr 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fuel filler door won't open when release is pressed 1998 Lincoln
should be an emergency cable to pull inside the car behind the filler cap
Jan 13, 2009 | 1997 Mazda MX-5 Miata
Washing machine creda front loader
I had the same Problem on a 17112e Creda, I took the top off and using a torch located the red plastic door release mechanism, I then pressed a white button in the centre of it and the door released. I believe that the washing machine was overloaded and auto cut out. I reloaded the machine with fewer items and it is now working.
Mar 20, 2006 | Creda W100FW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal De
