Run dos command through vb 6.0 without showing it
Hi!!!!!
i want to run dos commands trough vb6.0 without showing command prompt to the user..how it can be possible...this is regarding my project....
  • gkhire Mar 20, 2008
    plzz give me d solution.....
Shell "Cmd.exe /c dir"
/c for hide command window
/k for display
Posted on Jun 21, 2010
    Genius:
  • 3,587 Answers
Visual basic, on windows, right? jumping to dos, implies a command line, no? how else would you access a command line interface, if not through cmd?
Posted on Mar 20, 2008
How do i get my password
If you want to change a computer's sing-on password without actually knowing the original password, then today's your lucky day.
You don't need to be computer savvy to do this.
This is considering you know the ethics of privacy.
Please do not use this against anyone.
Okay, now that that's over with, here's how to change the sign-on password to a computer without knowing the original password...
Go to the start menu, then click on "run" (the command program).
Type in "cmd" (without the quotes).
Once the command window comes up type in: "net user"
After you type in "net user" it will list the user names of the computer.
You want to type in "net user" and the user name after it.
So if the username was Maya you would type in: net user maya.
After this it should say on the command window "you may change your password".
To change the password type in what you typed in the previous step but this time add the password to the end.
So if my password were abcd I would type in : net user maya abcd.
Change Administrator password using DOS Command
Use dos comand
The administrator account on a Windows machine is the main, root user name that gives full access to the machine.
Administrators should change this password frequently to avoid unauthorized access to the domain or desktop machine.
This can be done in the Windows Control Panel, or use the "net user" command in the Windows DOS prompt.
Log in to the machine using the administrator username and password.
You can also use an account that has administrator privileges on the domain or desktop computer.
Click the Windows "Start" button and select "Run" or "Start Search" (depending on your version of Windows).
In the text box displayed, enter "cmd" and press the "OK" button.
This opens the command prompt window.
Type "net user administrator <new password>" into the command prompt.
Replace "<new password>" with the password you want to set.
Enter the password again for confirmation.
Once you enter it again, the administrator password has been changed.
Test the new password by rebooting the machine and logging in with the new administrator password.
Apr 10, 2014 | Computers & Internet
My compaq presaario turns on and off without loading
Does it show a blue screen? If so you want to disable the automatic restart so you can read the error message.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 24, 2012 | Compaq Computers & Internet
Just installed Ubuntu Server. I need a graphical user interface, and downloaded one but computer still boots to dos-like interface. I don't know Linux commands. How to get GUI?
1-If you are presented with the command line after Linux boots, And after you login and end up at the command line prompt, you Type:
STARTX
The above command start up the GUI from the command line, and Get you in the Graphic GUI environment of Linux.
2-If you Linux computer start up with the GUI, and you are Taken to the desktop environment, there is a way to access the Linux command line.
From your desktop, you can go trough the startup menu and choose the " TERMINAL", and this will let you access the Command line. You will end you with a windows with the Command prompt from within the desktop.
In summary, accessing the command line interface or the GUI Can both be done on your Linux computer, weather your system is Setup to start with the Shell interface or the GUI.
Nov 28, 2011 | Canonical Ltd. Ubuntu
For Dos Command
Download a program called Belarc Advisor. There isn't a command that will allow you get the system board number from the DOS prompt without running a 3rd party application.
Jul 11, 2009 | Computers & Internet
How can I run a dos app without using a command prompt console?
vbscript should be able to do that you can swap between wscript ( which uses the gui ) or cscript ( which uses the command prompt )
May 07, 2009 | Computers & Internet
To run a DOS command without showing output to the user
You cannot execute a dos window withou atleast having it appear in the task bar as a running program in Windows. You can however start it minimized using a batch file and starting with the command:
START /MINIMIZED /WAIT COMMAND.COM
Depending on what you are trying to do you might want to look into VB scripting or WHS as an alternative to using CMD to parse commands.
Dec 16, 2008 | Microsoft Visual Basic 6.0 for PC
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
621 people viewed this question
David Payne
David Payne
