Acer aspire 9810 memory problems
Thanks for the tip Dan.
Yes maxing out at 2gig works well enough.
Acer state in they're manual that the max memory size is 4gig. However according to memory supplier,. Vista 32bit will only address 3.5gig of this or less. The bottom line is that I now have a spare gig of memory I cannot use unless of course there is a technical workaround for this?
Thanks again Dan.
  • 4,234 Answers
Two things you can check.
1) Verify that the Acer doesn't require a jumper change on the motherboard to support more than 2 Gig.
2) Verify that the particular version of Vista that you have will support more than 2 Gig as well. It is possible that the Vista installation process "checks" for available memory and loads based upon that number. I don't know that for sure, but other software has done this in the past. It is best to check.
Dan
Posted on Mar 20, 2008
SOURCE:
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
Is there any problem if i install a single 2gb memory at one slot on my acer aspire 4315?
max ram per slot is 1gb, for 2GB total. A 2 GB module will not work
http://www.crucial.com/store/listparts.aspx?model=Aspire%204315
Apr 03, 2010 | Acer Aspire 4315 Notebook
Hi have an Acer Aspire 9815k (9810). Just
Sounds Like a driver issue. Uninstall the Sound drivers in the device manager, and check with the Acer website and download the appropriate drivers for your laptop.
Oct 22, 2009 | Acer Aspire 9810 Notebook
How to Upgrade to max RAM
The Acer Aspire One can be upgraded to a total RAM of 2Gigs. This will allow for you to upgrade to Windows XP Pro and also to Microsoft Office 2003 as there is no version of Office Professional. If you would like more specifics on your particular model, please look here. http://www.laptopmag.com/review/laptops/acer-aspire-one-10-inch.aspx?page=3
Upgrading RAM is a fairly simple process. As this is a fairly compact laptop in design, you will have to upgrade to a new 2Gig RAM module and basically discard (or sell) the one you end up removing. In order to find out the type of RAM you'll need, remove the cover as show in the picture and the info for the existing RAM should be written on it.
Apr 19, 2009 | Computers & Internet
Acer Travelmate 529atxv states max memory as 512mb
512mb is the max memory amount this computer will accept.
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot. Two slots total. Hope this helps.
Mar 07, 2009 | Acer TravelMate 529ATX Notebook
Added new ram (2gig + 2gig) acer inspire 5610 and it won't boot back up. worked great before i added memory.
Unfortunately the max supported RAM size is 2GB. you cannot exceed that. Sorry for the dissapointing news!
Remove 2GB and it should boot back up fine!
Hope this helps, please rate well!
Mar 01, 2009 | Acer Aspire 3690-2196 Notebook
How to expand max memory capacity on acer e500
The Tech is correct. Two Gb Ram is the max ;which is based upon the BIOS and engineering of *********** board limiation.
Dec 23, 2008 | Acer Aspire E500 PC Desktop
Memory
OK! I have read about many people with this problem and I have had the same problem so maybe i can shed some light on it, here goes!...... I turns out that the intel chipset on this laptop will only handle 2gb of memory, not 4gb as Acer say in the manual. But, is this true i wonder! because I have tried 2 2gb sticks in my laptop and sure enough it wont work. However, I have now put in one 2gb module and one of the original 512mb modules and it works fine but vista said it only had 2gb and the bios sais 2.5gb! very strange but then I updated vista with service pack1 and now vista does see the full 2.5gb memory. So acer are still wrong which leads me to think that maybe this could be solved with bios updates in the near future (I am on bios 3.50)
Mar 28, 2008 | Acer Aspire 5670 Notebook
Computers & Internet Logo
597 people viewed this question
Ekse
Alun Cox
