Transit brackets I have a Indeset wixl163 washing machine It is vibrating badly.Could it be the transit bolts have not been taken out although i always thought they held it solid. Where are they located?
    Scholar:
  • 74 Answers
Hiya .. the transit bolts are located under the lid at either side ..or at the rear... they are fairly long bolts which hold the drum and balance in place.. until installation. they will be sheathed in fairly hefty rubber grommets.
Screws for removal of lid located at the rear..2- or 4.. remove these slide lid front to back.. remove bolts if they are they are present... refit lid... note uneven siting of an appliance can cause excessive vibration as well!
Let me know if this sorts your prob
Regards Faggly
Posted on Mar 20, 2008
Excessive vibrations on spin(transit bolts)
you must remove these transit bolts . after you do try it . of course the legs of the washer must be set to make the machine levl. and then make sure the lock nuts on each leg are tightened. with a level machine with the leg locknuts tight the machine should spin smoothly. if you fasled to remove the transit bolts first then you may have damaged the suspension. then you will have to call for professional service. good luck
Aug 04, 2010 | Washing Machines
When washing iwe get a horrible smell like bad
Is this a newly installed machine?
That smell would normally be associated with drains, indicating that the outlet from the machine to the drain is not correctly fitted with a trap.
Mar 25, 2010 | Indesit W 123 Front Load Washer
I left the transit bolts in our "brand new" zanussi washing machine and am afraid to use it as I do not know what damage might have been done.
Highly unlikely any damage will have been done so long as it hasnt been in use for a long time (weeks).
In a front loading washing machine, most of the mechanicals inside are held between springs at the top and dampers at the bottom. The transit bolts are used to minimse how much movement can ocour whilst the machine is in transit as excessive movement could damage the springs/dampers. When they are removed, normal movement of the mechanicals helps keep the machine stable and minmises vibration.
So, the worst that happens when the machine is used with the transit bolts in place is it vibrates alot, and possible moves about.
Remove the bolts as soon as possible and it should be fine.
Oct 04, 2009 | Zanussi ZWF12070 Front Load Washer
Vibration of the wash mashine
How old is the machine? Have transit bolts been removed? Older machine is possible bearing failure or spider breakage( a 1 in 10 wash with a temperature of 95 degrees celcius will extend life of a front loader!- an empty wash or towels or sheets at this temperature). A grinding noise can simply be a worn drive belt, rotating drum by hand and finding grinding and lateral movement equals bearing/spider failure. Also a simple case of Underlaoding the machine will cause unbalanced load and vibration.
May 22, 2009 | Washing Machines
Other than the floor, what else will cause a newly installed front loading washer to vibrate and wobble so badly that i don't dare use it ?
dID YOU REMOVE THE TRANSIT BRACKETS AT THE BACK OF THE MACHINE TWO BIG BOLTS USUALLY EITHER SIDE.
COMMON FAULT OF OWNER NOT REMOVING THE BRACKETS. CAUSES THE MACHINE TO GO JUMP AROUND
HOPE THIS HELPS
SORRY FOR THE CAPS
WASHDOCTOR
P.S REFER TO MANUAL FOR PRECISE INSTRUCTIONS
Aug 25, 2008 | Washing Machines
Vibrating across the floor
you have not removed the transit bolts!!!! do not use machine till you have done so as you can cause a lot of damage and it will not be covered under guarantee
Aug 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Shaking like crazy
ALERT. transit brackets still on machine ..REMOVE THEM;;
Nov 25, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
569 people viewed this question
Top Washing Machines Experts
