Question about Toshiba Satellite X205 Notebook
X205-SLi1 Speaker Problem: The left speaker is stuck in a constant thumping/tapping noise machine-gun noise pattern. You can actually see the left speaker go up and down repeatedly as it makes its tapping noise. The noise will stop when laptop is turned off, but will continue non-stop when laptop is turned-on. Thank you for your assistance. JC
  • Anonymous Apr 22, 2009
    Like the previous poster said its the far left speaker which is constanting beating at about 200 bpm. Im gonna go ahead and say the speaker needs to be replaced
    Genius:
  • 3,587 Answers
Sounds a lot like you have a speaker that's crying for removal and replacement..you could try to use the volume slider, with the left/right balance, and see if it's generic to the system, or just one particular application. sounds like it's happening all the time your computer is on
Posted on Mar 20, 2008
SOURCE:
Altec lansing t612 thumping noise
Your speaker is sensitive to subsonic transients produced by the amplifier driving it.
Jul 15, 2016 | Altec Lansing T612 - High End Speaker...
Some buzzing in left speaker when low notes played
A couple of possibilities
One the speaker broke loose, typically there is lock tight on the threads that hold the speaker in place, lower frequencies can also cause buzzing noise,
I have fixed this problem in the past with a hot glue gun, running a small bead carefully around the edges of the speaker, bonding it to the unit,
Another possibility is the speaker is blown or worn out, over time speakers can weaken from constant use and coil movement, in this case the speaker should be replaced...
Hope this helps?
Mar 13, 2015 | Yamaha P-105 Digital Piano, Black
Sound system makes a thump thump noise
Your speaker is now blown.. Replace the Speaker and you will get sound back instantly. Happened to my Drivers Speaker last week, replaced the speaker and life is good again.
Mar 01, 2014 | 2010 Kia Soul
Constant thumping noise
your speaker is compromised there is no fix only replacement
Jan 05, 2013 | Bose Companion 3 Computer Speakers
Microphone is not working
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
hope this helps
Apr 28, 2012 | Toshiba Satellite X205-S9810 X205 Series...
X205-SLI1 17" Notebook PC PC Notebook 3 beep
Memory problem:
Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 23, 2011 | Toshiba Satellite X205-SLI1 Notebook
Does the Toshiba X205-SLi1 have a recovery partition?
Hi joshpop1920,
"Go to this "Website!"
"Download the Manual!"
In the "Manual: search for the {Chapter} "System Restore."
It will explain the: [Recovery Process].
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1854787&rpn=PSPBUU&modelFilter=X205-SLi1&selCategory=2756709&selFamily=1073768663
Mar 12, 2011 | Toshiba Satellite X205-SLI1 Notebook
Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Nov 06, 2009 | Toshiba Satellite X205-SLI1 Notebook
Getting 3 beeps when starting the comp. with no screen.
some prblm is dere wid d ddr1 or ddr2 compatibility...jst check d compatibility of d ram n insert accordingly..having fit at both ends...that's it...it's not a big issue...
Apr 11, 2009 | Toshiba Satellite X205-SLI1 Notebook
Toshiba Satellite X205 Notebook Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
