I can't remember off the top of my head -- it's in User Tools, either under System Settings and then Address Book, or under Fax Settings. But you can download the manual here, and it will tell you:
hello there here is several links that will help you out ok best regards michael
RICOH AFICIO220ServiceManual
RICOH AFICIO220 - It's a complete servicemanual, and it's in PDF format. ... i got my servicemanualfor philips vr685-02. Thanks a lot for my very clear and ...www.user-manuals.com/service-manual-RICOH-AFICIO220.html - 73k - Cached
Enter in the user mode:
1.Press the Clear mode key.
2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
This will require a tech familiar with this machine to reset. The user code option is enabled by both a setting within service mode, and a jumper being disconnected on the motherboard of the copier. This jumper will need to be reconnected and the settings changed within service mode.
