Question about O2 Xda IIs Pocket PC
No backlight, the body always get hot every time i recharged the unit
Every time i recharge my O2 Xda lls the body of my unit always get hot and their is no backlight. i already try to troubleshoot by using the manual instruction and i did reset but still did not work...need help asap thanks!
    Problem Solver:
  • 5 Answers
Change the settings for the backlight.. just go to start>Settings>System>Backlight and use the tab to go to next page and there will be the setting for the backlight while on charge. Just move it up to desired lighting and there your done.
Posted on May 02, 2008
My O2 Xda lls Pocket Pc, I can't hear anything when i'm calling someone. no rings, nothing.. how can i solve this problem?
speakerphone inside your phone needs to be replaced by a professional. you can do it yourself.
Apr 28, 2010 | O2 Xda IIs Pocket PC
How do i change THE LANGUAGE OF O2 XDA lls Pocket PC
If the language is for the whole system, you have to change the rom of your phone. try to download roms from xda developers.com
Apr 04, 2010 | O2 Xda IIs Pocket PC
Hi i plug unit with battery for charging no display lcd and no light indicator colored orange . I take out battery pack and charge then it produce light orange-red indicator of unit. I noticed charging...
Hi I solved the problem by taking off the battery for around 1 hour.
I attached the battery again.
And press hold switch around 10 seconds.
The unit booted and it proceeded to auto configure and auto installed program soft wares.
I realized that the unit is self shutting off.
Solution is go to setting.go to system.go to back light menu.
on backlight on external power .Be sure to uncheck turn off backlight if devise is not used for 1 minute.
Be sure to check turn on the back light when button is pressed or the screen is tapped.
press ok to activate the setting.
For maximized battery power and optimized power usage .go also to back light and go to brightness level.
Slide the battery and power to almost the 2ndlevel .
Hope this also will be applicable to other o2 xda iis configuration.
Best regards
Jan 17, 2010 | O2 Xda IIs Pocket PC
To: O2 xda lls
hard reset only!here is manual
http://xda.o2.co.uk/pdf/user_manual/Detailed_XdaIIs_Windows_Userguide.pdf
Nov 19, 2009 | Computers & Internet
Same problem with the hot air 95 accord
You got to the station and say "hot air recharge please". They will let you know if that's something to try. They say most of the time the recharge won't last long enough because of leaks in the system, always a big problem.
Aug 14, 2009 | 1995 Honda Accord
How to hard reset my o2 xda II?
To perform a full reset
A full device reset clears memory, deletes all data, and restores the Pocket PC Phone to its default settings. Programs installed at the factory remain. All data that you have created and programs you have installed are erased.
Press and hold the Power button, and then use your stylus to press the “soft reset button” at the same time. Be sure you have backed up all your data on an SD card or on a desktop PC before performing a full reset. Hope this helps.
Jun 26, 2009 | O2 Xda IIs Pocket PC
O2 xda iis
Sorry yur power ic is damaged just replace this ic yur phone will work properlly...
Aug 13, 2008 | O2 Xda IIs Pocket PC
O2 XDA Zinc
How to hart reset or formating O2 Xda Zinc
Jun 03, 2008 | O2 Xda IIs Pocket PC
I have problem with my screen
hello ...i have the same problem and situation.Unfortunately that damaged the LCD already bec the glass cleaner absorbs the liquid that makes it unresponsive to taps. You got to have that replaced or have that checked by authorized dealers or repair centers.
Apr 11, 2008 | O2 Xda IIs Pocket PC
O2 XDA ii screen does not align
how to align screen xda ii
Mar 12, 2008 | O2 Xda II mini
O2 Xda IIs Pocket PC Logo
78 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
