Question about Dell UltraSharp E153FPb 15" LCD Flat Panel Monitor
Dell monitor E152fpb
I was given this monitor from my boss at work and the monitor worked fine there. He has a Dell PC
i got it home and it wont work with my desktop or notebook. they are both made by Packard Bell. I have downloaded and installed the drivers for this monitor but it doesnt change anything. The power is on and when i connect the Moniter lead to my computer the light on the monitor goes from green to orange.
Any help would be grately appreciated
  • 4,234 Answers
The orange light means that the moitor is not seeing any signal. Make sure that the cable is in the correct position on the PC. If that is correct, try it on another PC to determine whether or not the monitor was damaged internally during moving or the PC is not sending out a video signal.
Dan
Posted on Mar 20, 2008
INSTALL
Simply connect via VGA, DVI, or HDMI to video card.
Aug 26, 2012 | Dell E152FPb 15" TFT LCD Flat Panel...
Have a dell E152FPb flat screen monitor which doesnt stays black even when on light is green. have taken back off but no obvious bulging etc. what can i try to get some life back imto it please
The backlight controler board is faulty. You can try replacing any capacitors in this board even if they look OK. If this does not work then you need to replace the inverter board with a universal inverter board - you will need to work out the wiring details though.
Mar 10, 2011 | Dell E153FP 15" LCD Monitor
Dell E152FPB LCD no light
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Nov 10, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
The complaint for this DELL E152Fpb LCD Monitor was when switched on has power (LED lit) but no display ti goes yellow on the power led but it brings no display on the screen.
It is standby mode, no signal, It is possible that your computer is not POSTing.
Connect your screen to another computer/laptop, just to make sure, which component is not working. Either the Screen or the Computer.
Make sure the DVI/VGA cable is firmly connected as well as RAM modules and Graphics Card.
Please take the time to rate my expertise.
Thanks
Nov 01, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Upgraded to windows 7 and now my dell E152FPb monitor will not allow me to change the resolution. What can I do?
borkoven, Will E152FPD act same way when you reconnect it to a windows XP computer? 12fixlouie
Oct 24, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
After changing c5707/c5706 transistors its burnt after 10 minute? i have changed its 3 times, pls advise me about actual problem
On E152fpb dell only replace all driver transistor the c5706 or c5707 this 2 types of transistor is not desame one is PNP & NPN so you must be careful of replacing component maybe it will help you
Apr 26, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Dell e152FPB LCD monitor backlight power problem
Check the four transistors (c5707/5706) in the inverter section for shorts, board looks like this? http://www.lcdrepair.us/e152-e153fpb-inverter-power.html
Feb 20, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Can not display this video mode
If it is possible to boot this machine in safemode, you can boot it and change the resolution to low mode, and reboot the machine
Oct 14, 2009 | Dell E152FPb 15" TFT LCD Flat Panel...
Problem with Dell E152fpb computer screen
No It seems to be dry solder joints on the Invertor / powerboard.
Samir
Oct 25, 2008 | Dell E152FPb 15" TFT LCD Flat Panel...
Dell UltraSharp E153FPb 15" LCD Flat Panel Monitor Logo
347 people viewed this question
Alun Cox
