Question about Mercury P4VM800M7 Motherboard
USB device problem
Whenever , i plugin any USB device (like memory card reader , pen drive , blutooth device and etc)........given following problem will appear in quick launch bar
"USB Device Not Recoginized"
i am using ......
mercury PVM7 model motherboard
intel p4 2.8 ghz
256MB ram
seagate 80 GB HDD
windows xp(sp2) os
  • 28 Answers
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-2
Posted on Sep 03, 2009
  • 53 Answers
Dear sir,
first u check the usb settings in bios means it is enable or disable,u enable the usb.
Even it is not working problem with motherboard only .u go to nearest repair center
Posted on Mar 20, 2008
  • 38 Answers
Check the USB driver from Device Manager
install usb driver from your motherboard driver disk
SOURCE:
Tip
Removing Write Protection
Trouble:
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Fix:
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button disablewriteprotection_thumb.png
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
on Jun 19, 2010 | Computers & Internet
My 8gb transcend is write protected ..how to remove it
The procedure for removing the right protection is given in the website given below.
please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
Thanx
Jul 20, 2010 | Transcend (589307) Media
How can i remove the write protect in my memory card if it doesnt have a slidable lock
Thanx
Jul 20, 2010 | SanDisk 2GB microSD Memory Card
I need to know how to use the Sandisk card reader. can u give me instructions?
You should be able to plug the device in. Most operating systems will recognize the device and treat it as new hard drive.
Are you getting a request for a driver? If so, first let Windows look for the driver.
May 22, 2010 | SanDisk Extreme USB 2.0 Memory Card Reader
I want to formate my pendrive in which virus and is not removed in my computer
Hi
Thank you for your query
Please do the following to format your pen drive
1) Put the pen drive into the USB port
2) Double Click MY Computer
3) Find the USB drive in this windows i.e. it will be called USB 2.0 etc
4) Right click on the icon and then left click on Format
5) Choose NTFS from the option menu and then click format
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | SanDisk 8GB microSDHC Memory Card with...
My transcend pen drive didn't blinks...?
the connector that is build into the pen may be broken, if i were you i'd send pendrive to onrack recovery company, as home-way-fixing may corrupt data on pendrive
Sep 22, 2009 | Transcend (589307) Media
Cant
in jeneral memory card meance card reader ( mobile/d igitalcamer/phone cards where we put photo song.....etc) it is as pen drive device we put data directly in pen drive but in card reader . we put data in memory card through cardreader. both are use in computer usb port. computer dected card reader as apen drive.
are you not saying about ram ? it is also called memory. it is use in mother bord slot. they are white and plastic.
Jul 12, 2009 | Dell Dimension 2400 PC Desktop
How to install drivers of pen drive
your pen drive is not recognize by the usb port onyour computer, remove the pen drive from the port and insert it to another usb port on your computer, if you still having problems, restart the computer and try again on a different port.
USB drives do not drivers for it to work.
Jul 03, 2009 | SanDisk 8GB microSDHC Memory Card with...
Mercury P4VM800M7 Motherboard Logo
287 people viewed this question
Top Mercury Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Gustavo Ortiz
Gustavo Ortiz
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
