Restore point I could not find a restore point. I've only got a blank screen! there is no place to chek ted date only wight window.
  • 85 Answers
May be u tried any cleen up disk or urrestore monitor i off thats why u can'tfind anypointthere
Posted on Mar 22, 2008
USER GUIDE
Click "Start" in the lower-left corner of the Windows home screen, then click "Help and Support." Click "Undo changes to your computer with System Restore" beneath "Pick a task." The "Welcome to System Restore" screen will appear on the screen.
Click "Restore my computer to an earlier time," then click "Next."
Choose a previous time to restore your computer to by clicking one of the bold dates on the calendar that appears on the screen, then click "Next." Click "Next" again when a dialog box appears asking you to verify the restore point. Your computer will be restarted and restored to the previous point you indicated. If restoring that point does not work, repeat the process and restore the computer to a previous point.
CD/DVD Drive Does Not Appear In My Computer
Click "Toshiba Upper/Lower Limit Repair Tool" in the Resources section, then click the name of that same highlighted title in the Resolution section of the document to download the file. Save the file to your Windows desktop. The file name will be "RmvFltrs.exe."
5
Click "RmvFltrs.exe" on the Windows desktop if you are using Windows XP to run the installer program for the software; if you are using Windows Vista, right-click "RmvFltrs.exe," then click "Run as Administrator." Click "Allow" if User Account Control asks you if you want to allow an unidentified program to access your computer.
6
Restart your Windows XP or Vista computer to finalize the software installation. Your CD/DVD drive should appear in My Computer.
Display is Blank
7
Press a key on your Toshiba Satellite laptop. This will wake the laptop up if it is sleeping.
8
Press "Enter." If you have set up a password protected screensaver on your computer, a dialog box will pop up asking you to enter your password. Enter your password and press "Enter" again to access the laptop. Your screen will be blank prior to press "Enter" because you did not choose a screensaver.
9
Press the "Fn" and "F5" keys at the same time.You may have hit these buttons previously, causing the built-in laptop screen to go blank because the computer thinks the video is being sent to an external monitor. If you press the "Fn" and "F5" buttons and the display does not appear on the screen, press the buttons again to make sure your laptop screen is set as the default monitor.
Jan 10, 2013 | Toshiba Computers & Internet
Windows 7 hangs on start up
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
No date option means the drive is not being monitored for restore. Right click My Computer > Properties and enable.
Oct 25, 2012 | Lenovo IdeaCentre A600 (3011CKU) 21.5 in....
I've clicked on Abode settings on my screen which I don't want how do I undo this please
What settings changed on your screen? The icons got bigger or smaller? If so Click Start/Control Panel and look for Display or Appearance and Personalization. Open the display and click the Settings Tab to change the Resolution. The higher the resolution, the smaller the icons. The lower the resolution, the larger the icons.
If that is not what you are looking for you can always run System Restore to go to a Restore Point (date and Time) before you made the Adobe change. System Restore does not delete your data.
In Windows XP and Vista click Start/Programs/Accessories/System Tools/System Restore and select a restore point that was before you started having problems. There should be an option to see more restore points than the one that is shown.
In Windows 7 Click Start then in the search box type System Restore.
Again, System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected).
System Recovery on the other hand deletes everything and sets your system back to when you first purchased it.
May 05, 2012 | Dell Inspiron 1525 Laptop
Blank screen during playback with gigawire webcam
Switch On your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Jan 31, 2012 | Radio Shack VGA PC Camera Webcam
E640 REBOOT
Hi John,
I see you mentioned you update IE9 then you now get a blank screen...
If I may ask the blank screen showed up after the update or did it show up after restarting the computer?
If your getting a Blank screen when you boot into windows after the IE9 update, try rebooting then boot into Safemode.
Restart you computer then as soon as you see the Boot screen of you computer keep on Tapping f8 to get a list select safemode, then once it boots into safemode windows will load up in safemode on the issue and you can navigate arround to fix things that went wrong.
click on the Start Button on the lower left of the task bar then, click on Programs, select accessories then select system tools, look for system restore then select the option select a different restore point, on the window you may see a list of restore points hoping your system restore was turned on in the very beginning, once you have selected a restore point keep on clicking next then a warning will show just click next again then it will restart your computer.
System restore allows you to restore to a date where you had windows working fine without any problems so if you can get a restore point before updating IE9 then it is possible that you may be able to fix you windows back the way it was.
I hope that this will help,
michaelvincentc
Dec 22, 2011 | E-Machines W Computers & Internet
How to reset my laptop with a sandisk cruzer 8GB
If you have a problem with operating system, there are many solutions;
1. Repair operating system with Windows Boot able CD, or flash drive boot able windows.
2. Reinstall operating system with Windows Boot able CD, or flash drive boot able windows.
3. Using system restore.
Restore to date when system in normal condition. How; press START - All Programs - Accessories - System Tools - System Restore - Choose a different restore point - Next - select date when a computer in normal condition - Next - Finish. Wait until the process is complete - Restart.
4. Using image backup. You've been backing up the system, and save Them as image files. By using the backup image, system damage can be fixed. How: click START - Control Panels - System and Security (Back up your computer) - Restore - select image file you've ever created, and you save on your hard drive - Next - Wait until the process is complete - Restart.
From above solution, solution no.3 and 4, is the most easy and fast
I hope this information useful
Dec 02, 2011 | Toshiba Computers & Internet
How to reset my computer to an earlier date
If you are talking about in the Windows operating system all you have to do is move you cursor down to your task bar and all the way to the left. Right click on the time, and select "adjust date and time". Then type in or select your desired date and time and press okay. You can only change your time if you want, after that you are done.
Mar 01, 2011 | Toshiba Computers & Internet
Black screen
hi,
do you see any error or does it go blank after you see the windows logo,
if it goes blank after you see the windows logo, that means that there has been software misconfiguration at the level of windows operating system, restart your system using the power button and wehn you see the asus logo at start start tapping F8 key, it will lead you to a menu that will say boot into safe mode, select safe mode and enter, see if you are able to boot into safe mode, if you are then what we can do is restore your system back to a previous date
to do that in safe mode follow the following instructions
Caution: After a system restore the configurations/software that are done after the restore point will be lost
for system restore
click on start button > go to run > in there type in without quotes
"%systemroot%\system32\restore\rstrui.exe"
system restore window will open
  1. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  2. On the Select a Restore Point page, click the most recent system restore point in the On this list the dat eon which your computer was working, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  3. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  4. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  5. Click OK.
further Queries are welcome
If you find my solution helpfull please do rate me
Feb 24, 2009 | ASUS Eee 4G Notebook
TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Computers & Internet
Blank screen on acer aspire 5570z laptop
Hi Grneyes0725,
Thanks for the posting in FIXYA.
Could you please reboot Laptop in Safe mode.
Tapping F8 Key during Bootup. Select the option safe mode with networking.
Do the Error checking for each Hard Disk partition. Hope it fix the problem.
And if the problem is recent and date is known, its better to make a system restore.
1. Log on to Windows as Administrator.
2. Click Start --> All Programs --> Accessories --> System Tools --> click on System Restore. System Restore starts.
3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
4. On the Select a Restore Point page, click the most recent system checkpoint in the On this list, click a restore point list, and then click Next. A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer (normal mode now).
6. Log on to the computer as Administrator. The System Restore Restoration Complete page appears.
7. Click OK.
Best of Luck & Regards
ELLIN
Sep 14, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
