Question about Kyocera FS-720 Laser Printer
Red light error
It comes up with a red light error after switching the printer on
  • 1 more comment
  • Anonymous May 04, 2008
    i unistall my printer kyocera fs-720 but niot installing after that
  • dre64 May 04, 2008
    try system restore
  • Chris Schutte May 11, 2010
    Is the red light staying on or flashing?
Thanks guys
Posted on Nov 06, 2008
Hi Folks, I have just had the same problem with a Kyocera FS-720 that also had the red/orange attention LED staying on permanently after being turned on. Turned out to have an empty toner cartridge. After replacing the toner cartridge, printer is as good as new again.
Cheers
Charlie T
Posted on May 07, 2008
  • Haneen Shurman
    Haneen Shurman Dec 30, 2017
    Well I have currently the same problem knowing that the toner cartridge is not empty , can you help me find out the problem Charlie
Red light flashing
The red light is indication there is an error. Reset does not solve the problem. First solve the problem, like close all doors, or replace cartridges, then try to reset by switching off and unplug from the mains. Then reinsert the mains plug and switch on again.
If the red light comes back, you did not solve the problem. Read the manual, or give more details, so we can help.
Jul 18, 2014 | HP LaserJet 2550L Printer
Switch on the printer and it goes through its cycle and a red light comes on. With the black toner blinking. I have changed the toner switched on and this time just the red light comes on. Samsung...
unplog the printer from electrik for 10 minutes and try aggain, if the problem still occure try to update the soft ware using the web side from samsung for this printer, this should solf the problem.
Apr 18, 2011 | Samsung CLP-315W Laser Color Printer
The online error light is red on my ML-1610 Mono Laser Printer any ideas how to fix this?
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Jul 16, 2010 | Samsung ML 1610 Laser Printer
Installed new cartridge and it says low on ink why? also what does the red light mean when it comes on and why?it will not go off.
I have the same problem. I replaced the black and both lights blinking now. Then the red light came on the power switch indicator and an error code 3802 and 3808 message that says "call support". No answer at their phones.
I think I need to change brands.
May 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Red Indicator Light stays on-- "Online Error."
tray to powering off the printer wait about 10 second then swith on
i use to be too
Apr 29, 2009 | Samsung ML 2010 Laser Printer
One label prints, then red light comes on. We
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
Red light error :
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
Here is a trouble shooting guide:
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Red light on error button
First you have to see what is the error. The error msg will be displayed on ur monitor when the printer is on. Then it will be easy to rectify the problem.
Mar 16, 2009 | Brother HL 2140 Laser Printer
Light is red and not green
There may be several causes to this problem.
1/ The lid of the printer needs to be firmly shut before the Red light changes to Green.
2/ If the ribbon has come to the end then the red light will come on, change the ribbon.
3/ If you have changed label size and not recalibrated the printer to the label then the RED will come on.
Any error within the printer will bring the RED light on.
You can download the 2844 User Manual from
http://www.lancerlabels.co.uk/2844user.pdf
Jan 16, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Red light.
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=14082&prodoid=24875245&foid=31655
Mar 20, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Kyocera FS-720 Laser Printer Logo
941 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
