Printer jam problem
The problem is with this printer,it keeps having paper jam,even after i've removed them,they will jam again.i don't know what to this printer and i would appriciate any help i'd get,please help me with,the model of the printer is an hp hewlett packard laserjet5.
  • shaziakamran Sep 13, 2008
    i do not know how to take out the paper from printer if it's jam
  • Anonymous Feb 05, 2009
    pAPER JAM AFTER THAT PRINTER ERROR HAS OCCURED MESSAGE
  • 89 Answers
It is probably a matter of worn rollers which means paper jams will continue until they are changed out. Also, this machine does not have a seperation pad so you need to fan the **** of paper when you put it in to help the seperation process.
Posted on Mar 24, 2008
Paper jam in exit area
Hi
Disconnect it completely from power and re-connect again.
Sep 16, 2012 | Samsung SCX-4300 Monochrome Laser...
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
13.02.00 paper jam on tray 2. i have removed the tray and even the catridges but can't find any paper. I don't know where the sensor is as this may be the cause as well. Please need urgent...
Number 1 you failed to mention what kind of printer you have.
Number 2 when you print, does paper even feed into the printer?
When was the last time that you replaced the feed rollers?
Yes it is possible that a sensor is jammed. Before the 13.02 error,
did the printer actually have a paper jam? If yes, was there a piece of paper
missing from the jammed sheet or was it whole?
Jul 15, 2011 | Office Equipment & Supplies
Brother DCP-7020 Paper Jam, we keep having the paper jam at the paper exit at the top/back of machine. I've examined closely from front, back, bottom, even removing a few easily removed parts, but can...
This is caused by dirty exit roller. As this machine is a pain to dismantle I suggest that you try and clean these rollers ( 3 or 4 rubber small ) as they rotate. Opening and closing the front door will keep rotating them for you. Use a damp wrm water lint free cloth. I use a compound named Print Clean but metho can be used also.
May 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
My printer keeps telling me to remove jammed paper, but there is no paper in it!! Help, and thanks!
OK do one thing off the printer then restart it.Reset the printer from printer option botton. then off again. After that when you on the printer then the massage naver come.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Saying clear paper jam, I have done, there is no paper jam
Clearing a paper jam in a Lexmark laser printer is an easy thing to do. Laser printers produce high-quality products and are fairly complex machines, but paper jams (in most cases) can be solved mechanically with a little know-how and time. Follow these steps to learn how to clear a paper jam in a Lexmark laser printer.
  1. ep 1 Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Step 2 Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Step 3 Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Step 4 Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Step 5 Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Step 6 Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Step 7 Plug the printer back in, refill the paper tray and try to print again.
    • Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
    • To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
    • Always pull the paper “with the grain” of the mechanism, if possible. Pull it through the printer the way paper normally travels so that you don’t go against the gears.
    • For more serious repairs, contact an electronic store or professional repair person.
Nov 24, 2009 | Lexmark X4580 InkJet Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Hp Color LaserJet 3500 Paper Jam
The only way to find paper remnants is to unplug the printer and inspect the paper path. It also helps to have a good focusing flashlight, skinny needle nose pliers, a can of compressed air (used sparingly) and a long thin probe. Your specific printer should be giving you jam messages with a location code as well. I?ve attached a link to an HP page containing a diagram of the 3500 paper path and the error code jam locations: http://h41206.www4.hp.com/webapps/IV3/node.iv?locale=en_us&prodSeriesId=315862&node=prodITRC%2FNL_HW_IPG_plakCLJ3500_EN_01_E%2FN1%7C6%7C9&prodTypeId=18972&serverId=1#src I solved this problem in my shops years ago by not letting anyone else clear jams OR insisting that any paper removed as a result of a jam is given to me. If any corners or pieces are missing I know what to look for and approximately where. Good hunting and please don?t forget to rate this post.
Mar 20, 2007 | HP Color LaserJet 3500 Printer
270 people viewed this question
jasbo
jasbo
