Question about Bell & Howell Copiscan 8000 Spectrum Series Path-Through Scanner
Back pages of images too light
Well the frotn page scanning is ok but the back pages are to bright any advise what to do it shouldn be a software problem
  • 25 Answers
Not sure what you mean by "too bright." Its not really a term used in scanning. Do you mean the image is "washed out", that is , the letters are not very dark and blends in with the white of the page?
If this is a Copiscan model with a few months into heavy scanning, the problem will be dirt and debris in the rear camera. Bowe Bell & Howell did not cover the entrance to the camera with a glass on the older Copiscan series, so when it gets full of dust, you get a washed out effect.
There is a service menu that will allow the technician to calibrate the camera, but it isn't open to the average customer. (A series of F1 thru F3 sequence). Also, if it is a model using a greyscale board instead of the Kofax avocet card, then there is a scsi normalization that will help. Also, take the rear lamp , with power off of course, pull it out , spin it around and place it back in.
Posted on Jul 15, 2008
  • 490 Answers
It must be software setting. Try auto setting, else slightly darken output. You can also revers the same image and try out
S. Mohan
Posted on Mar 20, 2008
SOURCE:
I hava a canon dr-2010c scanner. but when I scan the paper through capture touch 2.0 than scanning very fine but when I scan through capture perfect 3.0 than show black page scanning.
Normally it is advisable to use only one Scanning Software. The software has various files which may overwrite the previously installed version. The later version works good.
It is also possible that the brightness/contrast settings in Captureperfect 3 is not proper. Try scanning after altering these.
S. Mohan, India
Apr 03, 2014 | Canon DR-2010C Flatbed Scanner
I have replaced the imaging unit and it still asks for a new one how do i reset it
folow the steps please:
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
May 19, 2011 | Samsung CLX-3175FN Printer
Canon DR-5010C when settings are changed to Auto Detection for page size gets an error message stating that "Scanning parameters are incorrect." I want to be able to scan stacks of paper of various sizes....
If you are using CapturePerfect 3, select page size as Auto-detection, detect size by Image width, Deskew by roller & Image, then you will get images exactly as that of the scanned image.
If you ae using CP2, then you can select Auto-detection AND page detection. The problem with CP2 is if the image is less than that of the guide-plate, you will get black background. You can clean this through software.
If you had select B&W scanning and chosen to save file in JPG format, the scanner will report error. JPG is only for Color/ Grey scale.
With CP2, I have observed that sometimes, the changes are not retained, unless you select 'default' first and alter the parameters. This is not found in CP3.
S. Mohan, Chennai, India.
Apr 28, 2010 | Canon DR-5010C Scanner
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
Scanning produces 1/2 page yellow
uninstall the drivers in add remove programs and restart the computer then re install the drivers ignore the new hardware wizard when it pops up close it. then run the cd. it sounds like the driver got corrupted
Jul 18, 2009 | HP Photosmart 3310 All-In-One InkJet...
MCF 6490CW SCAN AS A PDF
I was trying to figure out how to scan multi-page documents to a single file and found this on the Brother website:
Double-click on the ControlCenter3 icon located in the Task Tray to launch the program window.
Click on CONFIGURATION -> SCAN.
Choose the type of scan you require. The choices are: IMAGE,
E-MAIL, and FILE.
The Scan to configuration window will appear.
The SOFTWARE BUTTON tab configures the Scan to button within theControlCenter3 software interface. The DEVICE BUTTON tab configures the Scan to key on the Brother machine. Choose the tab you want to configure.
Under FILE TYPE select an option that allows multi-page documents:
a) PDF (*.PDF)
b) Tiff Multi-Page # Uncompressed (*.tif)
c) Tiff Multi-Page # Compressed (*.tif)
Click OK.
Apr 28, 2009 | Brother MFC 6490CW InkJet Printer
Unable to scan or copy.
I also just found that I have the same problem. I called HP and of course it is out of warranty. I have only scanned a few things.
I have never had any luck with HP/Compaq. I think it's safe to say, "Don't buy HP Compaq". We also have a Compaq Laptop that it a POS, too.
Feb 02, 2009 | HP Photosmart C5180 All-In-One InkJet...
Xerox 510 will not scan from ADF
If it is new, and not assuming there is a hardware problem with the scanner (some fault), might be a software problem. If the scanned image from the flabed is OK the drivers would be installed properly. You do not say which software you are using but when you have a "Professional" documentscanner and intend to use it for "production" scanning you need proper software also, To scan, to mix documents, rearrange pages, auto remove blank pages, deskew, produce small PDFs even when scanning color and so on. Look at PixEdit - it will do the job for you.
Jul 16, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Duplex- Back of page not clear
Clean the glass with Isopropyl alcohol. Set proper Contrast level. If the level is not okay, you should get atleast a dark/very light image. If there is no image at all reinstall driver. Run Scandisk on the Comp
S. Mohan
May 05, 2008 | Canon DR-9080C Path-Through Scanner
Bell & Howell Copiscan 8000 Spectrum Series Path-Through Scanner Logo
133 people viewed this question
Top Bell & Howell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Bell & Howell Office Equipment and Supply Expert? Answer questions, earn points and help others
