Question about Kyocera FS-720 Laser Printer
RED LIGHT ERROR
PRINTER RED LIGHT ERROR FROM START UP & DOESN'T RESPOND
  • dgsi Apr 10, 2008
    We have the same problem as well. After warm up the red solid alarm comes on
  • Chris Schutte May 11, 2010
    Is the red light flashing or just stayin on?
INSTALL MY PC THIS PRINTER FS-720
Posted on Jul 19, 2008
When i press start button on my Canon Gp225, it doesnt respond.. it dont even give any error msg also.. i tried loading more papers n closed the paper tray properly also.. tht gives proper sound also.. but...
if the start button doesn't responds could be that the microswitch/contact of start button needs to be cleaned/resoldered/changed.
You can try to apply small ammount of wd40 on the edge of start button. In some cases helps as first aid.
Call service!
Hope that helps!!!
Aug 29, 2011 | Office Equipment & Supplies
I have red light the second (toner) and the last lamp (exlamation). The first one i don't care, it was red since i charged it, but since the exclamation is red doesn't do anything and the green...
The toner cartridge is not installed, or the printer detects a toner cartridge error. The error is caused by a defective cartridge, an unsupported cartridge an invalid refill, or a cartridge meant to be used in another geographic region.
If the toner cartridge is not installed, install it. If the toner cartridge is installed, remove it and install a new toner cartridge.
For Cartridge errors, Press and release the right button twice briefly to display secondary error codes.
For further assistance, please contact Lexmark Technical Support.
Jun 29, 2011 | Lexmark E120n Laser Printer
Red and green lights flashing, won't print or respond to commands. Problem started when cleaning heads and subsequently testing with the print pattern. Monitor says a general printing error and suggests...
The heads are clogged. Unplug the printer remove the cartridges and dump them (never use the same brand of it or the same ink),pour some cleaning fluid there and leave it to soak. If you have some empty cartridges fill them with cleaning fluid and use them.
Oct 04, 2009 | Epson Stylus Photo 1290 InkJet Printer
My printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
Mar 10, 2009 | Epson Stylus Photo R200 InkJet Printer
Flashing Green and Red lights
i querried from epson site it says the ink is low, repalce cartridge
Step 1 WHICH MODEL ARE YOU USING? Stylus C44UX Step 2 What were you doing when the problem occurred? Turning on the printer Step 3 What happened when you were turning on your printer? An error appeared on its control panel Step 4 What is the power light's current state? Flashing Step 5 What is the error light's current state? Flashing Step 6 WHAT IS THE PRINTER'S STATUS? Ink low
Oct 28, 2008 | Epson Stylus C44UX InkJet Printer
Epson FX-890 All lights flashing
when switch printer on after replacing cartrige all the light on printer are flashing how can I reset it
Jun 27, 2008 | Epson FX 890 Matrix Printer
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
Stuck on Red
Normally mean fatal error on this machine you can hold the go button down for a couple of seconds and it might give you a secondary light sequence. Normally if the red light is on and nothing happens the most common fault is the fuser unit is not warming up.
You will have to replace the fuser unit, but this all depends on the second light sequence.
Thanks J
Nov 14, 2007 | HP LaserJet 2200D Printer
Kyocera FS-720 Laser Printer Logo
397 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
