Question about Sharp AJ-6010 All-In-One InkJet Printer
Sharp AJ-6010 Incompatible Ink
Hi, just want to ask from the experts, can i refil the cartridge of Sharp AJ-6010 printer? why is it that there is an error "incompatble ink" is there any tricks to solve this problem? thanks and more power
    Genius:
  • 3,587 Answers
Well..the compatibility is more from the type of cartridge, not the ink it self..
Posted on Mar 20, 2008
Hello i need the AJ 6010 printer Head please advige me
Kulwant Singh Pandori
p.andori@rediff.com
Posted on May 06, 2008
I have put a tesco hp compatible ink cartridge in my hp 2050 deskjet printer but a msg comes up INCOMPATIBLE INK CARTRIDGES The cartridges listed above are not intended for use in this printer as...
This model Cprinter may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Mar 26, 2013 | HP Deskjet 2050 All-in-One Printer
Sharp AJ-6010 Printer Driver for vista os
A bridge to far, sharp do not support this printer on vista and it is very unlikely they will
Sep 26, 2009 | Sharp AJ-6010 All-In-One InkJet Printer
How do i make printer accept refilled cartridge t
Maybe you did not refill and insert it very well.
follow this steps in refilling your ink
1. remove the ink cartridge from the printer
2. make a hole at the top end of the cartridge, the hole can be made under the label on the cartridge by using a sharp/hot pin.
3. if you are using a syringe and needle in refilling, make sure you did not insert it into the hole too much so that the cartridge does not get damaged in the process.
4. make sure the ink is not over-filled to avoid spillage which can cause a hell of damage on you printer as it does to my previous one.
5. Gently use the label or a masking tape to cover the hole and insert it into your printer.
Note: The printer gives a message that the cartridge is empty or non compatible, ignore the message and continue with your printing.
It is also advisable that you refill your cartridge not more than 2 times.
If this solution does not help you, contact me on holamydes@gmail.com for more assistance.
Aug 15, 2009 | HP DeskJet F4280 All In One Printer InkJet
After replacing ink cartridge printer dose not reconize one of six
Using refilled in cartridges and incompatible inks result in the following problems.
  • Refilled ink cartridges might leak and cause product damage. One method for refilling ink cartridges is to drill a hole through the cartridge, refill the ink, and then plug it. In some cases this plug does not hold, and the ink runs into the product and damages the printed circuit boards.
  • Refilled ink cartridges frequently exhibit spotty printing or fail to print. This problem might be a direct result of the nozzles being plugged with dried ink. Because the vents of the refilled cartridges have been opened, air is able to enter the cartridge and dry the ink.
  • Refilled ink cartridges might exhibit lower print quality, for the following reasons.
    • Printing algorithms used to create the various colors are based on particular printer inks. Using incompatible inks might result in color matching problems.
    • Refilled cartridges might have damaged nozzle orifices, result in various problems with print quality.
    • company products to which the printer belongs to can use a time delay between pages to accommodate the properties of the specific media type and ink being used. This prevents smearing problems from one page to the next. Using incompatible ink will alter the effects of this time delay and might result in poor print quality.
  • printer might not recognize refilled ink cartridges. The refilling process may involve altering the ink cartridge enough that the product is unable to recognize it. The condition of the print cartridge electrical contacts deteriorates with use. This also results in the product being unable to recognize the refilled cartridge.
  • Refilled ink cartridges might get stuck in the product. Because the cartridges from other manufacturers have been altered, cartridges might become stuck in the product. This problem might require that the product be disassembled to remove the cartridge.
  • printer at times cannot predict the long-term effects on product reliability from using different ink formulations.
try this.
please rate my solution.
have a nice day.
Jul 08, 2009 | Office Equipment & Supplies
Refill ink is giving me a error on my printer
Try another ink cartridge. Thats what I did. I found out that one of the ink cartridges I used was defective and actually had no ink so the unit was reading an error.
May 01, 2009 | Office Equipment & Supplies
Refilled cartridge problem
There's some kind of a chip chip in the catridge that notifies the printer that the same cartridge has been refilled. to get around this check keep atleast 2 or 3 empty cartridges, refill and cycle them. That should do the trick!
Dec 02, 2008 | Sharp UX-B750 Inkjet Fax
Cannon Incompatible Ink Cartridge Issue
I refilled my ink cartridge and you have to reset the chip on the cartridge,go back where you refilled your ink and ask them to reset the chip.Thats if you refilled the ink or you baught a canon one return it to the store.
Dan
Sep 10, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
SLITELY OLDER AJ5030
Uninstall the drivers then reinstall them this sometimes works.
Thanks J
Feb 17, 2008 | Sharp AJ-6010 All-In-One InkJet Printer
Sharp AJ-6010 All-In-One InkJet Printer Logo
95 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
