Question about ASUS P5RD1-VM Motherboard
Sata connection i want to connect internat sata hard drive. can you guide me how can i connect?
  • 38 Answers
U can connect through sata external casing
or if u have sata port on your motherboard then u can attach with sata cable and sata power cable
Posted on Mar 20, 2008
SOURCE:
Is a ide a hard drive
You should check what kind of hard drive is using your computer. If it has less then 5 years probably hard drives are sata.
watch this tutorial
Instructions on USB To SATA IDE Adapters Cables
How to connect SATA devices in PATA IDE only PC system
Modding Guide Inline SATA Connectors
How to connect an IDE drive to SATA motherboard
Jul 22, 2015 | Hard Computers & Internet
Tip
How to connect your hard drive to your motherboard The first thing you have to...
The first thing you have to figure out is what type of hard drive you have, a PATA or a SATA drive.
PATA = Parallel ATA
This type of drive uses the older IDE connections. Most of your current motherboards still have aleast one IDE connection to support the ROM drives on the market that have not moved over to SATA connections but you can still connect a hard drive to this connection if needed. The thing to keep in mind is that you can only connect 2 IDE devices to one IDE connection on the motherboard.
Here is an example of an IDE cable. If you can see there are tabs on the cable to make sure you line up the pins properly.
SATA = Serial Advanced Technology Attachment
This type is now the standard that most hard drives are. Also note that alot of your ROM drives are switching over to this format as well.
Here is an example of a SATA cable.
In regards to power connectors If you are using a PATA drive then you will use the Molex power connector. Note some of the early SATA drives use this power connector as well.
For the SATA drives you would use the SATA power connector. Note if your power supply does not have this connection you can get an adapter that goes from a Molex connection to the SATA connector.
Next you will need to find the connectors for the hard drive on your motherboard. Below if pictures of the 2 connection types.
IDE/PATA motherboard connectors
SATA motherboard connectors
on Sep 01, 2010 | Computers & Internet
How 2 install a triple format sata internal drive in a gateway desk top
check for a open sata port on your computer. if there is one connect the hard drive with a SATA cable to the sata port on the motherboard.
connect the sata power to the hard drive or a molex to the hard drive if you do not have one. do not connect sata and molex to the hard drive together. if you don't have a molex connect you will need a molex to sata power adapter.
after connecting the hard drive to your pc. turn it on. in windows xp it will auto detect the hard drive and may prompt you to format the hard drive.
Mar 28, 2011 | Computers & Internet
I have a k8upgrade vm800 motherboard. I want to install a sata hdd for storage only but the bios is not seeing the sata connection. Is there any soloution to make this possible or are the sata connections...
Is the drive initialised ... if not it will not exist on your system.
1.1 Serial ATA (SATA) Hard Disks Installation
This motherboard adopts VIA VT8237 southbridge chipset that
supports Serial ATA (SATA) hard disks. You may install SATA hard
disks on this motherboard for internal storage devices. This
section will guide you to install the SATA hard disks.
STEP 1: Install the SATA hard disks into the drive bays of your
STEP 2: Connect the SATA power cable to the SATA hard disk.
STEP 3: Connect one end of the SATA data cable to the
STEP 4: Connect the other end of the SATA data cable to the
chassis.
motherboard's SATA connector.
SATA hard disk.
Nov 25, 2017 | Asrock K8Upgrade-VM800 Motherboard
Hi, i have the noted type hard drive and i have just moved house. since then my hard drive wont connect to my pc. the light comes on and every thing looks ok but she wont connect. my other hard drive works...
does it just beep and is not reconized by your P.C.? if so continue to read,
If you get no joy using the Troubleshooting Guide then try this...
don't worry if you are a novice like me, the thread is very easy to follow.
Look inside your P.C. 1st to check SATA data connection type.
eSATA is a different connection from SATA so you might need an eSATA data lead if you follow the guide in the link, not sure if it just external connections only and plain SATA connection inside.
Google image 'eSATA' data lead/cable and you will see the difference between the eSATA and SATA connection if you don't already know.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t​=84 Thread can be found in 'Technical' under 'General Technical Issues'
Aug 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do i fix an external hard drive (seagate freeagent) that makes a beeping sound and is not recognized by my system ?
My neighbour has the Seagate FreeAgent Desk 500GB (Externel HardDrive), and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t​=84 Thread can be found in 'Technical' under 'General Technical Issues' Dont worry if your a novice like me with computers, the guide is quite easy to follow...
Aug 08, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My seagate hard drive wont power on,it sounds like it trys to spin then stops then trys again,my computer wont read that its connected
Do you have an different power supply to try with the hard drive? I had the exact same problem with a WD MyBook and the power supply was weak. I had the drive for a little over a year when this happened. Thank goodness for multiple year warranties on the MyBook!
Mar 11, 2010 | Seagate FreeAgent Pro 1TB External USB...
I SEAMED TO HAVE LOST IMAGE FROM MY VIDEO CARD AFTER ADJUSTING MY SATA CABLES
- Re-check all internat and external connection.
- Remove and re-set VGA card
I this not solve, leave only minimal devices connected to MB (Keyboard VGA, CPU and RAM, disconnectt allother) and check image.
Oct 19, 2009 | Gigabyte GA-K8NNXP nVIDIA nFORCE3 CHIPSET,...
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
Hard drive crash on dell 2400. Bought new Seagate 500gb hard drive. Installed with sata port to motherboard connected. On BIOS setup enabled sata port to auto, only two selections off/auto. On atempting to...
you will have to install a driver before it picks your sata drive up. when your cd starts to install youll see an option F6 to install sata drivers from a floppy
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
let me know if that guide helps
Aug 11, 2008 | Computers & Internet
ASUS P5RD1-VM Motherboard Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
