Question about Baby Gear
Noise on my engine
What should i do?? actualy if i switch on the A/C, the noise will happend something like a bearing tensioner is damaged..so the point is eaither i should buy the new part and changed the two parts(belt and tensioner)..or just changed the belting only..because to get the two parts is so expensive.. please solve these problem if you expert..
  • 50 Answers
Ok if its the a/c just remove the belt and test the pullys for noise and ware but if you still get the noise and it is comming from the cam belt GET IT LOOKED AT if the belt snaps you will need to remove the cylinder head and replace the valves cost you a lot of cash
andy
Posted on May 27, 2008
Tapping Noise that does not slow with engine RPM ?
If there is an ABS, check for sensor damage. Check for tire tread damage.
Jul 16, 2016 | Cars & Trucks
2004 Cavalier Engine Noise
Hi there:Check this information about "engine noses"...
ENGINE CLICKING NOISES
A clicking or tapping noise that gets louder when you rev the engine is probably "tappet" or upper valvetrain noise caused by one of several things: low oil pressure, excessive valve lash, or worn or damaged parts.
First, check the engine dipstick to see if the oil level is low. If low, add oil to bring it back up to the full mark. Is the engine still noisy? Check your oil pressure. A low gauge reading (or oil warning light) would indicate a serious internal engine problem that is preventing normal oil pressure from reaching the upper valvetrain components. The cause might be a worn or damaged oil pump, a clogged oil pump pickup screen or a plugged up oil filter. Using too thick a viscosity of motor oil during cold weather can also slow down the flow of oil to the upper valvetrain, causing noise and wear.
COLLAPSED LIFTER NOISE
Worn, leaky or dirty lifters can also cause valvetrain noise. If oil delivery is restricted to the lifters (plugged oil galley or low oil pressure), the lifters won't "pump up" to take up the normal slack in the valvetrain. A "collapsed" lifter will then allow excessive valve lash and noise.
VALVE LASH NOISE
If you can rule out lubrication-related problems as a cause, the next step would be to remove the valve cover(s) and check valve lash. On older import engines, mechanical lifters require periodic valve lash adjustments (typically every 30,000 miles). Too much space between the tips of the rocker arms and valve stems can make the valvetrain noisy -- and possibly cause accelerated wear of both parts.
To measure (and adjust) valve lash, you need a feeler gauge. The gauge is slid between the tip of the valve stem and rocker arm (or the cam follower or the cam itself on overhead cam engines) when the piston is at top dead center (valve fully closed). Refer to a manual for the specified lash and adjustment procedure. Also, note whether the lash spec is for a hot or cold engine (this makes a big difference!).
On engines with hydraulic lifters, oil pressure pumps up the lifters when the engine is running to maintain zero lash in the valvetrain. This results in quiet operation. So if the rocker arms are clattering, it tells you something is amiss (bad lifter or worn or damaged parts) or the rocker arms need adjusting.
DAMAGED ENGINE PARTS NOISE
Inspect the valvetrain components. Excessive wear on the ends of the rocker arms, cam followers (overhead cam engines) and/or valve stems can open up the valve lash and cause noise. So too can a bent pushrod or a broken valve spring.
RAPPING OR DEEP KNOCKING ENGINE SOUND
Usually bad news. A deep rapping noise from the engine is usually "rod knock," a condition brought on by extreme bearing wear or damage. If the rod bearings are worn or loose enough to make a dull, hammering noise, you're driving on borrowed time. Sooner or later one of the bearings will fail, and when it does one of two things will happen: the bearing will seize and lock up the engine, or it will attempt to seize and break a rod. Either way your engine will suffer major damage and have to be rebuilt or replaced.
Bearing noise is not unusual in high mileage engines as well as those that have been neglected and have not had the oil and filter changed regularly. It can also be caused by low oil pressure, using too light a viscosity oil, oil breakdown, dirty oil or dirt in the crankcase, excessive blowby from worn rings and/or cylinders (gasoline dilutes and thins the oil), incorrect engine assembly (bearings too loose), loose or broken connecting rod bolts, or abusive driving.
Bearing wear can be checked by dropping the oil pan and inspecting the rod and main bearings. If the bearings are badly worn, damaged or loose, replacing the bearings may buy you some time. But if the bearings are badly worn or damaged, the crankshaft will probably have to be resurfaced - which means a complete engine overhaul or replacing the engine is the vehicle is worth the expense.
ENGINE PINGS OR KNOCKS WHEN ACCELERATING
The cause here may be Spark Knock (Detonation) caused by an inoperative EGR valve, overadvanced ignition timing, engine overheating, carbon buildup in the combustion chambers, or low octane fuel.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Mar 02, 2012 | 2004 Chevrolet Cavalier
Hi, i have a 2003 toyota camry v6. everyone is saying the the bearings will need to be changed if i am going to change the timing belt. is this true thanks
If you change the timing belt it is reccomended to also change the tensioner and idler pulleys as well, depending on the mileage. You can change just the belt but it is a little risky, considering you can't actively see what's going on in there. If your timing belt slips on that engine, There's a good chance of doing major damage.
Nov 23, 2010 | 2003 Toyota Camry
Engine makes a screaching noise when 1st starting until it warms up
Auxhilary belt slipping... could just require more tension but not expensive to replace if required.
Feb 21, 2010 | 2006 Nissan Altima
Rubbing sound in motor when car is running. Sounds like a belt is rubbing or something is grinding as it is turning when motor runs. Any ideas?
hi from uk may i offer advice ? considering age of car and possible high milage ?? if you have not replaced the cambelt+tensioner which should be donearound 60,000 mls have it checked asap as if belt or tensioner fails you are looking at serious damage ! however this rubbing noise? may turn out to be some other fault like alternator bearing? or water pump but as you mention rubbing and especially grinding? i would suspect c/belt+tensioner ? so resist driving too far untill this noise is investigated sorry unable to provide a diagnosis as have not heard noise but hope you take advice given ?
Dec 11, 2009 | 2001 Hyundai Sonata
I have a 2000 honda shadow 750 with 30000 miles, it has a noise in the front head of the engine when its hot and the engine is reved up. i set the valves and looked at the timing chain tensioner when i was...
If it's a wrist pin or a rod bearing you are taking a chance on heavy damage if you run it until something breaks. Maybe you could get a Motorcycle Mechanic to listen to it and give you an opinion. I think the odds would favor a rod bearing.
Aug 28, 2009 | 2000 Honda VT 750 CD Shadow A.C.E. Deluxe
I have a high pitched noise which appears to be coming from front right engine compartment (as you are looking at the engine) which sounds kind of like a belt that is squealing. It is intermittent. Just...
Could be several things. WHICH ENGINE?.. 4 cylinder (has three belts, power steering/water pump, alternator & A/C compressor, one tensioner pully A/C compressor), The V6 2.7 (has only one belt, 1 Idler pully and 1 tensioner pully), the V6 3.5 has two belts - A/C/alternator, and power steering - there are two tensioner pullys). Noises can be caused by the belt(s) themselves, pullys, bearings, pully bearings, water pump shaft bearings (or belts/pullys rubbing up against something). Let's not forget that there is also belt(s) behind the Timing Belt cover as well as pullys and bearings associated with the timing system. You could start by removing one accy drive belt at a time (alternator, water pump, compressor, power steering, etc) to see whether or not the noise goes away in each case. If after each case, you discover the noise is still there, it's probably behind the timing belt cover (idler/tensioner pully, water pump shaft bearing, crankshaft bearing, etc.). Good Luck
Jun 29, 2009 | 2004 Hyundai Santa Fe
The tension pully 4 serpintine belt making funny noises
The bearings in the tensioner are shot, and it's time to replace it. This is also a good time to replace the serpentine belt.
Jun 03, 2009 | 2001 Pontiac Grand Prix
Enginge making noise sometimes.
did you check your belt tension pulley
Jan 17, 2009 | 1998 Honda Civic
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
