Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
No color and no sound....
I just got a "used"/"returned" viewsonic LCD at a great price. I brought it home to find that there is no color when hooked to TV cable outlet and no sound. Color does appear on the menu functions, etc. Can you tell me if there is a setting or two gone bad or if it's terminal. I can take it back soon, but for a second TV in my house, it'll be worth a try at fixing. Thanks!
    Sergeant:
  • 395 Answers
Try auto programing it, if that doesn't cure it replace the main board. you may need to contact the manufacturer for the repair. if this unit was a return to stock item then you should be able to have warranty on it. waranties are from the time of purchase return to stock items are considered as new resaleable items if sold as new discounted. it is up to the retailer to deturmine if the product is resaleable and not damaged. if sold as damaged you have no warranty check the sales slip.
Posted on Mar 21, 2008
SOURCE:
Have great picture no sound. The buttons turn volume up and down but I can not get sound
If you are using HDMI cable make sure it can transmit audio as well, as some cables don't do this I believe. Other wise, replace it.
Jun 30, 2014 | ViewSonic N4285p 42 in. LCD TV
Green and yellow color with viewsonic pj551 projector
the LCD panels are failing
the price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Feb 11, 2014 | ViewSonic PJ-551 Home Theater Projector:...
I am using a Viewsonic VX2235WM monitor for photo editing
Hi!
Its actually normal. That normally happens to some monitor models at the 6500K setting. Try a higher one.
I hope this helps.
Jubert
May 18, 2010 | ViewSonic VX2235wm LCD Monitor
Black screen with pulsing flickers of light
More likely to be capacitors failure in the power supply, worst case will be the lamps. You need to open it up and inspect the caps first, look for cap with buliging top/seal, see example of failed VIEWSONIC monitors due to bad caps (903b may be the sam as 902b): http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 21, 2010 | ViewSonic VA902B 19" LCD Monitor
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
No sound on some channels
Had same problem on Viera 3D Plasma TH-P54VT20A
Select Sound from setup menu and ensure SPDIF Selection is set to PCM (not Auto)
Feb 28, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Red color problem
Could be a bad main board or a bad LCD panel.
Make sure your cable is not causing it by wiggling it at each end.
Check that none of the capacitors on the main board or power board are bad.
Call Viewsonic and find your closest service provider. Have them check on the price of the main board. If it's under $50 it might be worth buying to see if it fixes the ptoblem.
Nov 15, 2007 | ViewSonic VX924 19" LCD Monitor
IBM LCD computer monitor is dim
Your backlight may be going bad, or the small controller board may be going bad also. You will have to contact ViewSonic for prices. It is not that difficult to change them out.
Oct 24, 2007 | ViewSonic VA721 17" LCD Monitor
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
63 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
