Stuck during cycle
I have a Daewoo Direct Drive washing machine that seems to get stuck with 11 minutes left getting onto the spin cycle
  • mamazoo2 Jul 08, 2008
    kenmore washing machine about 10 years old is stuck in final rinse cycle.
    Went to start her up but all it does is go into final rinse cycle; my laundry is all the way up to the top of my shoot!!!!
  • 185 Answers
Put a new timer in it
Posted on Mar 26, 2008
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
Cotton program stuck on wash cycle with 1 minute left
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
Feb 06, 2014 | Hotpoint Ultima WF865 Front Load Washer
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Jan 19, 2010 | Kenmore Washing Machines
I have an LG front loader, gets stuck on spin cycle at 9 min
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | LG Washing Machines
Won't complete wash cycle, stuck at wash after time end!
check heater or thermostat,check is it heat water
if not heat water then heater or thermostat is broken.if you have ohm meter you can check both
,unscrew behind sheet metal and find heater disconnect one wire from it and check it(meter must show some value e.g.30 ohm).
Jul 05, 2009 | Washing Machines
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
Gets stuck on timer and wont count down
We had a similar situation with our LG washer. It was not a timer problem.
The machine was not entering the spin cycle and was just stuck in limbo. A sensor or something was not being satisfied and allowing the progression to the next cycle. Our problem had to do with the drain line; it seemed as if it was air locked?? After lowering the drain line height (to reduce the head pressure), and manually draining some water out of the drainage cap (where the strainer is located) onto the floor, the sensor became satisfied and the machine completed its cycles properly.
What told me that it was not a timer issue was the fact that on different wash settings (normal, heavy, quick cycle), the machine timer would get stuck at different countdown points (22mins, 12mins, etc.).
Jan 17, 2009 | Washing Machines
Washer dryer sticks on j cycle does not spin or drain
check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Aug 21, 2008 | Zanussi W1242W Front Load Washer
Maytag LAT9356AAE drive pulley stuck during spin cycle
I had the same problem called a repair guy who told me the transmission is ceased up and the main bearing and seal is shot. Told me that Maytag uses defective parts in their machines and recommended direct-drive washer. Repair would cost more than to buy new. Sorry!
Nov 09, 2007 | Washing Machines
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
