Need to set Samsung HD080HJ/P as slave, what pins do I need to jump
  • Anonymous Jun 04, 2008
    WITH OR W/O jumpers it doesnt appear as SLAVE!
  • 117 Answers
Hi
remove all the jumpers then it will work as slave
Posted on Mar 20, 2008
2 Suggested Answers
siawolf
  • 749 Answers
SOURCE: pin settings on a samsung hd080hj/p sata hdd
Hope this helps.
Posted on Apr 11, 2009
Hd not recognized in dell optiplex gx150
Quick look at info form DEll gx150 Dell Search All Dell com shows me your motherboard is useing 40 pin ATA interface. So you need to be sure the drive is set to "master" or "Slave" and plugged into the ribbon for the interface in correct order. Master is located at the end of cable, slave is in the middle of the ribbon. Drives also have jumping pins that need to be set for Master and slave. There is a difference from one manufacturer to another. But the info is on the drive itself most time. Look close at the label on the drive for the settings for slave mode.
May 26, 2014 | Dell OptiPlex GX150 - Celeron...
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
Samsung sp251n hard drive. Using as slave. Only 150GB identified in device manager but no pins inserted. Where do I put the pin? Can't find any manuals online
Your hard drive may have two partitions, the first partition configured as 150Gb and the remainding 100Gb partition may not be set up and formatted.
The jumper settings may be printed on the label on the hard drive.
No jumpers are required for a Slave drive.
Jun 29, 2011 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
I have a dell computer and installing a samsung dvd-writer model sh-222 and it is not seeing it. How do the cable get installed on the slave or master?
if your using sata connect then it really does not matter the mother board will detect it as it wants though it should be plugged into master 1 and hdd into master 0 if your using the older type ribbon then you must make sure that the dvd player has its jumping pin plugged into slave at the back of the dvd writer. there is a small cluster of 6 pins with a small plastic jumper that needs to be put on were it says slave
best of luck need more help feel free to email
merry christmas
Dec 07, 2010 | Samsung Computers & Internet
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
How can i make my Samsung sp0802 hard drive become the master instead of the slave... thank you very much
Hi Good day!!! follow this
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
7. Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
Don't forget to vote thanks!!!
Nov 02, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Jumper setting
Jump the middle pins, second set from the right when looking straight on with the power connector on the right.
Worldvet
Nov 17, 2008 | Quantum Fireball Plus AS (QMP20000AS-A)...
Old maxtor harddrive
Most Maxtor Drives have jumper setting so that if "Jumper 50" is set; the two pins farthest from the power jack, is Master Drive. No pin jumper set, Slave or Cable Select. I hope this helps.
Aug 30, 2008 | Quantum Fireball Plus AS (QMP20000AS-A)...
Computers & Internet Logo
1,854 people viewed this question
David Payne
David Payne
