Question about Orion 15" Competition Subwoofer H2 15D4 Car Speaker
Orion hcca hi i have a 15"orion hcca 2007 model and i was just wondering what the specs for a ported box with a rectangle port and if u could give me th dimensions.
    Sergeant:
  • 300 Answers
The owner's manual states the ported box should be:
  • 4.00 cu ft.
  • Port diameter = 4"
  • Port length = 14"
It doesn't mention round vs. rectangular port. For more details, you may want to contact Orion.
Posted on Mar 20, 2008
Subwoofer box specs for single 12" 2500 xtc
Magnat does not post the specs on any speakers! The construction of a speaker box means that you need to know what the following:
1. Diameter of the speaker
2. The tuning or resonant frequency of the speaker
3. The depth of the speaker
4. How much space the speaker frame displaces.
5. The thickness of the wood.
6. The bracing
7. The port (if you port it) needs specs for its displacement
8. The ports volume transmission factor.
9. Whether you want it rectangle, square or trapezoid.
May 06, 2013 | Car Audio & Video
Specs for orion 12" hcca
* Sensitivity: 84 dB
* RMS Power Range : 2000 Watts
* Peak Power Handling: 4000 Watts
* Impedance: 2 Ohm
* Diameter: 12 Inch
Features
* 4" Copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
* Continuous power handling will be 1500W (under rated)
* Burp power in excess of 5000W
* X-Max estimated at 30mm (total travel 4" peak to peak)
* Field Replaceable Cone / Voice coil / Spider Assembly
* Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
* Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
* Enhanced voice coil cooling system (forced convection ? aluminum heat sinking ? shorting rings to reduce inductive heating)
* Dimensions (in) 11.9 x 10.7
Jan 04, 2011 | Orion HCCA 12D Car Speaker
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Spacks on 15" orion 2 xtreme sub
Here are the Specs from Orion's spec sheet.
Sensitivity @ 2.84V/1m 93DB
FS 23Hz
QMS 9.05
QES 0.47
Qts 0.44
BL (Force Factor) 8.7 TM
SD (Piston Area) 500 sq.CM \ 78 sq. in.
VAS (Volume Acoustic suspension) 224 Liters \ 7.92cu.ft
Xmax 7.75MM \ 0.30 in.
Enclosure Recommendations
Sealed Volume 1.60 cu. ft.
Vented Volume 2.75 cu. ft.
Port Dia (Inside Dia.) 4 in.
Port Length 8.5 in.
Nov 07, 2009 | Orion Xtreme XTR15d Car Speaker
To make a box for a single hcca 12 inch
3/4 inch partical board 2inch wood screws,make sure that you read the spec size because thats what makes you deep bass.Peace
Oct 30, 2009 | Orion HCCA 12D Car Speaker
Have an old model orion amp needing specifications
the specs are as follows
250watts x1 at 4 ohms
400watts x1 at 2 ohms
600watts x1 at 1 ohm
it is bridgeable and has a 50 amp maxi fuse
May 09, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion 15" Competition Subwoofer H2 15D4 Car Speaker Logo
446 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Mark Skinner
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
