Question about SanDisk Sansa e250 MP3 Player
Sansa e 250 is not working
Its shows only blank screen
  • Anonymous Dec 16, 2008
    I have the same issue. This is a refurbished e250 that I got from Woot.com. When I plug it into the USB cable, the blue ring lights, but the display does not come on. If you hold down the power button, the blue ring turns off. If you plug it back in or push the power button again, all you get is the blue ring. The screen never comes on. I know it wasn't tampered with as it was still sealed and had all of the protective stickers on the body. Any ideas?
  • Anonymous Jan 27, 2009
    The screen will not come on but the blue light comes on when charging. I think maybe this thing is a piece of junk. Sure, I've turned it off and let it sit overnight, I held the power off to reset it and left it charge for a couple hours. It still will not work.
  • 758 Answers
I would recommend that you tried to reset the device if you have not done so..to reset the device press the power button for about 15 to 20 seconds..the device should shut down and then the firmware should reset...Please reply back to let me know the outcome...I hope this helps
Please rate accordingly
Thank You
Computerrep
Posted on Mar 20, 2008
SOURCE:
My Sansa Clip screen is not showing up (it is
it is probably defective. take it back to the store and replace it
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
Sansa e250 Menu won't show!!!! please help!!
http://www.sansa.com/support/sansa_e200/faqs
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I hope that helps. If not, please post a comment with an update to your problem.
Jan 01, 2009 | SanDisk Sansa e250 MP3 Player
My sansa view screen
that happened to my sansa e 250 so i called sandisk and they gave me a new one
Jul 07, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Blank Screen
try letting the battery run out than plug it into your computer and see if that works
it sounds dumb but i had a similar problem and it worked
Mar 28, 2008 | SanDisk Sansa e260 MP3 Player
My sansa 250 e
try running your sansa out of battery so the screen shows [to low of battery] then plug in your sansa to your computer and resync your music
Feb 09, 2008 | SanDisk Sansa e200 MP3 Player
Sansa wont work
Once you have it in recovery mode, create a file called "sansa.fmt" and put in on "16mb" (Which is what your sansa shows up as in My Computer when it is in recovery mode). Once you have put the file on the "16mb" disconnect the cable and allow the device to restart unlocking it before it boots back up.
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
