Americana parts Who sells parts for Americana (GE) washing machines. We need a pump for a AW9850H
    President:
  • 1,294 Answers
Go to: espares.co.uk
or RepairClinic.com
only for the US I think............
Posted on Mar 20, 2008
SOURCE:
Where would I get part we4x615 for an old ge dryer
What part is it? Lots of parts for sale on ebay. And need I mention, search google. Depending on where you live, there may be some appliance parts distributors that will sell parts retail to anyone. I found a new exact replacement belt for our 25 year old washing machine at such a place.
Apr 02, 2016 | GE Dryers
GE washer model#WBVH5200J2WW wash machine will not pump out water, will fill but will not pump out- any suggestions would be Great
Pump is toast can be fixed at repair shop or tech guy but usually better off with new washer parts labor not cheap chance happen again likely
Feb 21, 2013 | GE WSXH208A Front Load Washer
Changing pump on whirlpool washing machine WFS1072AW. I need a new pump (so I've been told as the single part isn't available for sale) as I've broken the black screw/cap that seals the pump. I...
take your new pump back and look in the paper for someone who sells used washers and call to see if they have the part u need,they getthe washers for free to remove may have what u need
Sep 17, 2011 | Whirlpool Washing Machines
My ge washer does not wash, it just spins. Help me fix pls.
if you mean it does not adjatate that would be your adjatater coupler grab adjatater at bottom both sides pull adjatater up it will be hard but it will come. when that comes of you will see adjatater coupler remove bolt in center of it that part will pull up. now to replace that part ge changed it about 2 years ago when you get the new coupler you will need the new bolt. 'GE sells that coupler as a kit comes with the new bolt thats the way to go...if I helped you please vote if you need more help please ask good luck
Feb 08, 2011 | Washing Machines
Ge washing machine wsxh208a1ww, The dial seems to get stuck during all cycles. If you go out and manually turn the dial one click it will keeping going. But it takes forever to do a load of laundry since...
The bad news is that you most likely need a new timer. I get mine (used) from e-bay after looking up the parts at "Sears Parts" by model number. Sears will sell you new parts by model number for your GE.
Be blessed.
Nov 08, 2010 | GE Washer Washing Machine Timer WH12X1000
What water filter would be used on a ge americana A4425GDTWW refrigerator?
Check at Lowes, they care a 5 year in-line Water filter that works wonders for clear purified ice and water. Cost about $40 bucks, but well worth that expense.
Aug 19, 2010 | GE Americana A4425GDTWW Side by Side...
My GE space saver stackable washing machine will
Im haveing the same exact problem on the same exact machine... I have taken all the pannels off, and drained the water. I was wondering if there may be a way that the pump lost it's prime and needs to be re-primed? (wishfull thinking on my part.) There was no indication that the pump burnt out, it just stopped working instantly with no symptoms. The other functions seem to work, it will agitate the laundry, and then will just stop when it comes to the pump cycle. Any help is appreciated. Thank You.
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
GE model number WWA7070VBLHA machine will not
first,check for any obstructions in the tub to pump then from the pump to the house drain,including and kinked hoses,if the washer senses any back pressure from these it won't drain or spin,also check the pump inside to make sure there are no impellers broken or missing on the pump or debris inside the pump
Apr 01, 2010 | Washing Machines
Broken ice maker/ water
If your ice maker has parts missing and you can not get the water to fill you don't have too many options I am sorry to say because yours is electronic.(No Replacement Parts) Part number Click Here=>WR30X10093 Point and Click Appliance Repair Sell Genuine OEM replacement parts. Ebay sells parts for less but the are counterfeits. And I'm a little with the angry with them when they claim to have the real thing and you can not even buy wholesale from GE at those prices. I would like someone to test the voltage to the water control valve when someone presses dispense water. If you get 120 volts to the side of the valve that dispenses water and nothing comes out I believe your ice maker and dual water control valve are defective. Part number for your water control valve is Click here=> WR57X10050
I'm very good with your model and its problems so if you need help please let me know. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Feb 09, 2010 | GE Americana A4425GDTWW Side by Side...
Washing Machines Logo
253 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
