I have a scart(out) to rgb phono 3 plus 2 audio when I connect I get a message ;Mode not supported&; I am trying to free up a scart socket on my tv and also improve my picture.
  • 372 Answers
Hi.
I think you are A little confused.
The 5 phono connections are for component this is not compatible with scart.
You may be able to use A svhs lead if your tv & item you wish to connect have svhs sockets & then usu red & white phono for the audio.
http://dysonmanuals.llc.nu/
Posted on Mar 21, 2008
I download a programme on my MacBook and want to play it via our TV but have to use the computer speakers for sound. Can we get the sound through the TV speakers?
It depends what connections you have on the TV. By using a headphone splitter socket you can put that into the speaker socket of your computer. Your speakers plug into one side of it and the other can take the audio connections back to your TV. However if you have terminated the ends of the cable with RCA type phono plugs, (image2) you will need to have audio in sockets on the TV. Some TV still have a scart connector and you can get a scart to phono plugs lead. You will also need a coupler to connect them (image 3) See images. But as I say it depends what sockets are on the TV.
Nov 27, 2017 | The Audio Players & Recorders
KEEP GETTING MESSAGE ON TV (RGB ON TV SCART HAS BEEN ENABLED)
trouble shooting common problems when using RGB ...
https://www.retrogamingcables.co.uk/trouble-shooting-guide-for-rgb-sca...
No video or sound on tv when using RGB SCART cable. Check that the SCART socket you have plugged the SCART cable into is an RGB enabled port (this is ... Some TVsets display an 'RGB' message in the top right of the screen for a short ...
SCART - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/SCART
WikipediaThe signals carried by SCART include both composite and RGB (with composite ... A VCR will often have two SCART sockets, to connect it to the TV ("up", ... SCART enables a device to command the TV to very quickly switch between signals, ... The box can instead ask the TV to stop displaying the normal signal and ...
How to use your TV as a computer monitor for gaming, videos
www.cnet.com > Home Entertainment
CNETJan 26, 2012 - Many modern video cards have an HDMI output. ... The trick, of course, is finding a TV with RGB-PC inputs. ... You can also send him a message on Twitter: @TechWriterGeoff. ... (Or just enable game/graphic mode) ... As yet I've been unable to find anything online that lists TVs that do or don't work with PCs ...
Scart fully RGB enabled? ' AVForums
Feb 09, 2016 | Televison & Video
HOW I CAN HAVE OUTPUT FRO AUDIO LINE ROM LG 55LH5000???
Hi, sorry but Most LG's no longer have audio outputs. The easiest way to get it ,You need to take the audio output from the source i.e. "cable box output"..if you have of course...
However whether your TV has this output or not we need to make some tests..5 different connections possibilities provided below.
(not by priority..you can start with any of it ).Below ,there is a sample TV back panel picture as well
Possible CONNECTIONS:
1) 2x RCA ports red / white is audio out ( L + R ) of TV to Stereo..
2) You can get also the audio digital output from the TV to a A/V receiver. the tv's optical audio out is stereo only mainly designed for freeview or tv audio to be output,
set the audio ouput on the TV menu to Dolby Digital, connect a digital optical out directly to the A/V receiver to receive audio signals.
3) since your TV has :2 x HDMI, SCART, AV, Component Video, VGA-sub, USB 2.0, connections,you may use the SCART plug to get Audio output for your TV .
TV's SCART connector which has 21 pins and "2x Audio Output " pins should be in it.
you need to buy an adapter called " RGB Scart Male to 3 RCA AV Female Adapter Converter" that can easily be found any electronic Market..one example as found eBay URL is below..
http://cgi.ebay.com/RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter-/130389078197
After you get this adapter,you need to carry the audio signal from SCART's RCA plugs to your Receiver with a 2x RCA (white/red ) cable.(if this does not work ,mfg should state somewhere in the manual..as your TV's "SCART socket IN only" ) if you properly connect IN/OUT plugs you will able to get the audio signal of the TV thru stereo..I recommend 2 $ value "RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter" with IN/OUT switch on it.
4) use HDMI connection of TV if you have HDMI input on your stereo of course...
5) if these are not an audio-out on one of these connectors , so you'll need to use the headphone socket if you want to plug it into a stereo. you need a cable 2x RCA to 3.5mm Headphone jack.
( This is the last ditch solution , since it mutes the whole sound.) ..
NOTE: if you connect this, pls be careful,your TV voice level will drive the stereo volume....
Hope this helps!..if more help requires Would you please let me know the result ?
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for us
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
I have a baird OR42BAFHD tv and am trying to connect it to my hi-fi. The hi-fi only has the usual auxillary red and white input jacks but i cannot see were i can connect them to the tv which has several...
Hdmi is digital minded while your hi-fi is analogue signals, you have two possible options I think if your TV has no phono audio out.
Your scarts (number 1 only) will have analogue in's and out's a scart lead with audio in/out to phono (come with a switch mostly) or adaptor is required some I have seen at one time had a plug one end and socket the other with output phono's in the middle, so to monitor signals going each way (TV > VCR or VCR > TV).
If you are not using the scart then just a simple scart to phono will do, note scart sockets on an TV only one will give an output.
The other route is a converter for hdmi a device that will convert digital signals to analogue, while the video element can have problems (on cheap units) through poor design/technicals the audio should present no problem, look for hdmi to audio converters.
Hope this helps.........
Sep 26, 2017 | Televison & Video
I have a Toshiba 3387DB TV and am trying to connect it to my laptop. Tried to use DVI (out of laptop) to RGB phonos cable. Then through a scart adapter into the Scart 1 socket at back of TV. Manual says...
You need to convert the component sync signals into a composite sync compatible with SCART. The red, green and blue signals can be connected through as-is.
Mar 21, 2011 | Toshiba 3387DB TV
Can't connect to the TV. How do I do this?
In the UK (and some other countries) you will need a SCART to SCART cable. Simply plug it into appropriate sockets on rear of TV & DVD player.
Elsewhere you will need a 3 plug RCA (phono) cable. Plug into colour coded sockets on both sets.
Use TV remote 'mode' button to switch from TV antenna signal source to RGB or other source as appropriate
Feb 18, 2011 | Haier DVD101 DVD Player
The picture is blue when I play a dvd. I recently connected it to a new Vizio TV. The other tv it was connected to gave us a good picture.
Check your connections for faults, also some connections on TV's are for RGB inputs, so you might have to try another connector or if you can switch the DVD's output to RGB etc.
Apr 04, 2010 | GoVideo DVR4000 DVD Player/VCR
I need to connect tv to hifi
Usually, most TV's have at least one SCART socket with all 21 pins connected. If so, you will be able to buy a SCART to PHONO adaptor quite cheap from places like Ebay. Try the link I have attached below for example:
http://cgi.ebay.co.uk/GOLD-SCART-ADAPTER-3-x-RCA-PHONO-S-Video-SVIDEO-Adaptor_W0QQitemZ360162931117QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item53db6231ad
Other types of adaptor are available, in the form of a cable assembly, which has a SCART socket on one end and either 2 or 3 PHONO plugs on the other end of the cable.
This may also work for you.
Nov 19, 2009 | Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Help
you cannot get your tv to play surround sound through the speakers, but if your tv has either a scart 21 pin socket or an audio out, you can fit a scart to phono adapter and connect the phono plugs to the audio left right input on your sound system, likewise if you have audio left and right output(phono) on the tv, connect to audio in on your unit. You should have a choice of output channels on the system menu, similiar to DVD/video1/video2 or output 1 and 2 or auxilliary 1 and 2
Jun 04, 2007 | Audiovox DV1532 System
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
