Installing 2 hard drive
Hi
i want to know how to install 2 hard disk in 1 computer .
thank you
gurdeep singh
  • 38 Answers
If ur hard drive is IDE port then
attach the 1st end of ide cable to the motherboard and second end of ide cable {IDE1}to the hard disk {make this hard disk MASTER by change the jumper settings }
attach the second hard disk to ide cable {IDE 2} make this hard disk SLAVE by remove the jumper from hdd
Posted on Mar 20, 2008
SOURCE:
After installing a new hard drive in my desktop computer, it still does not work. It says no boot device available. Sata's 0 & 1 installed but 2 & 3 uninstalled
No boot device available means the boot device hard drive on your system has no bootable operating system installed on it, or it is faulty. In the BIOS setup program, does the computer recognize the hard drive you installed, and is it included in the boot device list? If you installed a new hard drive because of a failure of the C: drive, the new hard disk does not come with an operating system. You have to install that on the new hard drive from the manufacturer's system restore disks. SATA channels 1 and 2 are just the connections on the motherboard for devices, and usually have a hard drive on one connection and a cd rom drive on the other. Giving the model and manufacturer of your computer might provide more clues.
Feb 04, 2017 | Hard Computers & Internet
When switcthing on my Advent netbook it comes up with the error message Windows Boot Manager Windows Falied to Start. A recent hardware or software change might be the cause. To fix the problem: 1....
Hi sioban_bros,
Based on your situation. I suggest trying the following steps:
1. restart the computer and keep pressing F8; Use Last Known Good Configuration.
2.If the issue still occurs after that, I suggest testing if we can boot from a Windows XP disk. If so, please install Windows XP on another partition and access your important data.
3. After backing up those data, you can use Windows XP disk to format the drive and reinstall your preferred operating system.
4. However, if we cannot boot from a Windows XP disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
To access the data on the drive, you can try to install the hard drive on another computer.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Advent Netbook
I newly perches spice gsm+cdma QT56 mobile but usb data cable driver cd not including in free items so i want usb data cable driver..pls help me if possible for u so call me my no. 9310489081 i m working...
Fixed for you (as best i could):
I recently purchased a Spice QT56 mobile phone. Unfortunatly during opening of said item i discovered the lack of (couldn't make out due to idiotic English but guessing) both the USB cable and the driver CD. Please be a good sport and contact me if you are able to help, my phone number(ironic hey?) is 9310489081. I'm working in Reliance Communication. (More idiotic English).
Kind Thanks
Gurdeep Singh
Aug 23, 2010 | Computers & Internet
I have a k8upgrade vm800 motherboard. I want to install a sata hdd for storage only but the bios is not seeing the sata connection. Is there any soloution to make this possible or are the sata connections...
Is the drive initialised ... if not it will not exist on your system.
1.1 Serial ATA (SATA) Hard Disks Installation
This motherboard adopts VIA VT8237 southbridge chipset that
supports Serial ATA (SATA) hard disks. You may install SATA hard
disks on this motherboard for internal storage devices. This
section will guide you to install the SATA hard disks.
STEP 1: Install the SATA hard disks into the drive bays of your
STEP 2: Connect the SATA power cable to the SATA hard disk.
STEP 3: Connect one end of the SATA data cable to the
STEP 4: Connect the other end of the SATA data cable to the
chassis.
motherboard's SATA connector.
SATA hard disk.
Nov 25, 2017 | Asrock K8Upgrade-VM800 Motherboard
Low disk space on Vista Home Premium
hi this is kamal,
pls try to format your system and install windows file in your c drives and this problem will not come again./
if it comes so pls let me know
regards
kamal singh
Oct 08, 2009 | Microsoft Windows Vista Home Premium with...
XP Prof installation can not find the Hard disk drive
hi,this is very simple problem.
before installing XP press F2 (go in system setup)
and there look for every option,there will be an option for hard disk.on that option select "SATA"
AND THEN PRESS F10(to save your choice)
after that exit and insert XP cd,window will start installing.
cheers
Jul 16, 2009 | Computers & Internet
How do I install windows XP on Compaq CQ40 327TU laptop
Try downloading Hiren Boot CD and run you can resize the Harddisk accordingly.
Mar 31, 2009 | Computers & Internet
2 hard disks
Because you have a dual boot system, you have two 'C' drives, which in fact is a good idea if you get a system failure on the drive you are using, you can select the other and still view any files on the other drive through my computer.
f using XP, right click my computer, then properties, then click advanced tab, then startup and recovery listing click settings, at the top system startup, select the default operating system, then click EDIT button, then delete the value that points to the other hard drive more than likely listed as disc1, disk 0 will be the one you have connected as master boot hard drive
Aug 29, 2008 | Microsoft Windows XP Professional With...
Hard Disk Problem
first download and install Drive Rescue . Click on Find lost drive, select the drive you miss and click "find logical drives". Now you should access all of your files. Save them to another drive and format the hard disk.
hope to be helpful
Riccardo
Aug 03, 2008 | Computers & Internet
Newby
Hi There OceanStar Thank You For Your Post
Best Solution Reboot The Computer With A New Install On Windows And See How You Go It Could Also Be A Faulty Hard Drive Try Installing A New Windows And See How You Go If Not Try Installing A New Hard Drive
Hope This Helps And Remember If You Get Time To Please Rate Me If his Helped :)
Thank You
FixYa
Jan 12, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
383 people viewed this question
Ekse
Alun Cox
