Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
We just had this happen. Our Dryer went on LOC for no reason. We cut the power from the breaker box and turned it back on and then the dryer worked fine. We will be calling the place we bought it from though. This was really a pain.
Neither option helped cut ther breaker box, and then pressed select and option at same time with no results still showing LOC and not responding at all
didn't work
Worked for me!
i am so glad, i looked on here, i had the same problem and i pushed the option and the select button together for a little while and then it finally turned off and the dryer worked again. Thank you
Mine does have a Select key nor an Options key ???
I do the control and select button and when it comes up with 50 seconds on the dryer and then I push start and all the lights but the like the control button comes on and I won't start up and you got a
Pressing Select & Options simultaneously for 20 seconds worked for me.
Holding cancel and option key simultaneously worked for me. The options and select button together did not.
Holding the select and options buttons together worked fine thanks
Loc dice la traba de control esta activada que significa eso
Tienes k desconectar el aparato
I pushed the select and options and it unlocked but still want turn on the cycle status lights all come on , I need help please if anyone can, thank you.
When we put the new cord on we plugged it in and it run and we open the door to shut it off and somebody had the wires laying up next to the tub and we had a shock inside so I had to get a new breaker and now we're doesn't do anything can you give me
Dryer stop E68 is on display
Unplugging it worked for mine.
it work ,,, yeahhhhhh thanks
