Question about Teac CD-X8 CD Shelf System
Buzz or annoyign static sound from speakers when CD is played
What can I do to solve this problem? would I be better off asking the seller for a refund?
    Master:
    Sergeant:
  • 462 Answers
You can either use good quality thick insulated wires, also keep the power source far from speakers also try to keep the speakers little away from main unit.
Thankyou
Posted on Mar 20, 2008
Static coming from speakers
Not much information here but I will try my best, could be a problem with the cable your using between the speakers and the mp3 player, you could have a dry joint, if it's like a "hum" sound your getting it's a bad ground, without the mp3 playing plugged in tap the end of the stereo minijack cable with the speakers turned up? hear the 50hz buzz - if the interference sounds the same it's most likely a bad cable or bad connector on the speakers. I would need to either hear the interference to determine what fault it is or if you can describe it better i.e. what it sounds like.
Mar 31, 2014 | Altec Lansing Multimedia Computer Speakers
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
Mar 25, 2013 | Audio Players & Recorders
I have a JVC MX-GT80 there is a problem with it, it turns on just fine but does not give sound, plays cds and everything the only problem is no sound when this happened there was sound then i heard a pop...
It looks like you've either blown the speakers of the amplifier itself. What were you doing when you got the pop and the sound stopped? (Playing CD or from External Source and at what volume level?)
If there is no sound at all from the speakers, not even a crackle or buzz then it's more than likely you've blown the amplifier.
You could narrow the fault by trying these speakers on another unit or another set of speakers on this unit.
If you require further assistance then please ask.
May 10, 2011 | JVC MX-GT80 Shelf System
Speakers buzz with no sound
Is this only with CD, only with THAT CD, or with nothing in particular selected or playing?
Check all connections for tightness as bad cable shield connections will let emitted noise into the system. Ditto for signal or speaker cables routed near power cables, TV's, other electrical sources.
Sometimews reversing the AC power cord polarity can resolve buzz/hum.
Feb 20, 2010 | Philips HTS3440/37 System
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
Static from speaker
Try playing around on the volume control panel. The pan might have been played with, along with other things.
Feb 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Feb 16, 2009 | Sony CDX-CA700X CD Player
In play-back, buzzing/static after 10+ seconds of recorded message
unplug power adapter for about
30 minutes (this solved my problem of a buzz on the outgoing message)
Mar 09, 2008 | AT&T 1717 Digital Answering Machine
Sound problems
are you sure you have plugged in the speakers properly? maybe u inserted the cable in the wrong port or u just didnt insert the cable property. A loose connection can cause static and obviously it wont play anything. Please check.
Dec 24, 2007 | Harman Kardon HK19.5 Computer Speakers
Car stereo static
Sounds like you may have an output transistor/module about to go out.
May 10, 2007 | iLO XM-MP3-CD Car Stereo
Teac CD-X8 CD Shelf System Logo
199 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
