Question about Akai PT46DL10 46" HDTV-Ready Television
Bad Picture. The picture is getting worse and I hear a whining sound when I turn the tv on. Is this a color wheel or the lamp needing replacement.
  • Anonymous May 26, 2008
  • pelling1234 Jul 28, 2008
    i don't think it's your lamp, i have the same problem, the sound is like a loud fan and the picture looks a little like sepia, i think it's the colour wheel, anyone else got an idea for this?
    An expert whose answer gotĀ voted for 100 times.
  • 317 Answers
Yes color wheel.
Posted on Aug 03, 2008
What would effect the picture quality the color wheel or lamp?
The color wheel is your suspect.......usually whines a bit
when bad. In a quiet room, you can hear it when the TV is powered on or off. It spins at 9,000 rpm ( wears out the bearing).
The lamp will not exhibit those symptoms....
Apr 26, 2014 | Televison & Video
I have a samsung hln507 and there is no picture. we start the tv, it has a high pitched whining sound, the fan and the color wheel are spinning, but there is no picture. after about 10 seconds the tv turns...
The colors wheel is dead.That why,u hearing high pitched whining sound.The colors wheel is spinning off of is motor axis and grinding it sides walls,that where the high pitched whining sound came from.Hire a tv Tech. for the colors wheel changing,because it requiring to take out alots of the machanicals parts itself,before u can come to the colors wheel itself to change it.
Oct 16, 2010 | Samsung HLN507 50" Rear Projection...
TV picture does not turn on
No,this tv have a colors wheel,it dead.The tv turn black&white,make loud grinding sound,make loud noises like a motor.All indication the colors wheel is spinning off of it axis motor and not functioning anymore.Hire a tv replaced the colors wheel,very difficult to replaced,many machanicals parts to take out,before even can see the colors wheel to replaced.
Jul 07, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Projection tv has really loud buzz or hum
You may not see any deterioration in the picture when the color wheel begins to go bad. The noise will get louder and eventually, it will shut down or the wheel will shatter while the motor continues to spin. If that happens, you'll have a black and white picture.
If its a Samsung DLP that is mercury vapor lamp driven, its a safe bet the color wheel is going bad.
Feb 11, 2009 | Samsung HL-R6167W 61" HDTV
No picture
what happens when you plug it in. and push the button. do you hear any sounds. like a whining. motor running?.... before the lamp fires the color wheel must reach speed. this is that whining.. if you dont hear that it MAY be stalled color wheel. in the shop however we have replaced alot of optical engines in these sets..
Jan 15, 2009 | RCA D52W23 52" HDTV CRT TV
Mitsubishi wd-65831 one night worked fine next day nothin..
If you hear a whining noise, the odds are it is the color wheel, the bearings are bad in it and will need to be replaced as a whole unit, kinda pricey, my suggestion, sale the bulb and all boards in it and which should fetch about 400+ and invest in a new TV, a color wheel is pricey unless you can find a deal
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture when I turn the TV on, I do get sound
You either have a bad lamp or color wheel. You should always try the lamp first and 9 times out of 10 that is the problem. If you heard any grinding or whining sound or your unit vibrates it would be the color wheel.
Apr 07, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Akai PT46DL10 46" HDTV-Ready Television Logo
63 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
