Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60" Philips Projection... Erratic red color.
Hey guys... I'd appreciate some insight if you could...
I started with the problem of needing a coolant fluid change... so I tried changing the coolant inside the TV... ended up dropping spilling some drops of old coolant on the board with my first attempt at the blue CRT. So, I stopped what I was doing, and removed the crt assemblies from TV and took out the board and went through a thorough and careful cleaning up of the fluid.
With the CRTs out of the TV, I cleaned the other lenses and changed fluids of the Green and Red CRTs.
So... I put it back together and with minor adjustments, I had the prettiest picture I've seen from the thing since I brought it home in 2000... I watched it for a couple hours before declaring victory and hitting bed.
Well, that didn't last long, apparantly after about 45 of viewing the next morning, the convergence went haywire. All 3 colors went nutty and none were on the same convergence... and after a couple minutes, I was left with wiggly convergence lines and no picture what-so-ever.
So... I thought maybe I missed some spilt fluid and went to work in re-disassembling the thing. I didn't see any evidence of residue anywhere, and even used some compressed air to make sure nothing was hiding.
I put it back together and found that I once again had a picture... but the red convergence was severely pulsing. The Blue and Green lined up fine. I used the convergence menu to get the Red as close as I could... but couldn't get it right. I noticed that the Red would be more tame when I toned down the Red intensity adjustment, but the first colorful picture that showed up on the TV would scramble the whole screen.
If I turn up the Red intensity adjustment... not maxed or even halfway... it hums (which is a reassuring sound) and affects the other two colors by causing them to severely flicker and sometimes shut off entirely.
I went into the factory adjustment screen in hopes to fix the convergence, and got things just about perfect... but as soon as I started watching something on the screen, the Red would again flare.
For now, I have the Red intensity adjustment turned all the way down... and am living with a mostly Blue and Green screen (the red still shows a bit)... which still looks better than the picture I had before I tried changing the fluid... I've also toned down the TV's color, brightness, and picture settings because when a screen of intense red or orange comes on, the tv tends to scramble...
Another thing that I tried was swapping the convergence connections for the Red and Blue... by hooking the Blue CRT to the red controls, I was able to easily converge the Blue and the Green in the factory screen... but the Blue control wasn't able to fix any of the pulsing of the Red CRT
So, any ideas?
Sorry about the book... but I figured more information would be better than less...thanks!
  • 1 more comment
  • PFFB Mar 20, 2008
    Thanks for the reply.
    So you think that the problem is within the circuitry and not the Red CRT itself? I suppose that is good news so long as the circuit board is still good...
    Any recommendation on the type of alcohol/cleaner? Tomorrow's holiday would be a good day to celebrate inside the back of the TV... so hopefully I can have an update by then.
    Thanks again.
  • PFFB Mar 21, 2008
    Winner!
    I thought I might need to use denatured alcohol... so I ran out last night to pick some up.
    Well, apparantly my thorough cleaning wasn't thorough enough. I guess the alcohol draws out any residue and when the alcohol evaporates, the tiny droplets of the glycol are left. Well, there was a considerable amount of droplets that were left behind.
    Another thing... I didn't take apart the retaining clips that hold some of the components to the metal uprights the first time, and clean the barrier sheets. I did that this time and found a couple that were wet, I guess the compressed air caused the glycol to migrate there. Oops.
    As for the boards... where I couldn't get a brush, I literally flooded with the alcohol and again used compressed air to flush out any residue and repeated until no more droplets appeared.
    It took about 2 hours, but I had the thing apart and back together and working... it took considerably longer to get the convergence back in shape. After chasing a moving object for the past couple of days, the red convergence wasn't pretty.
    I stuck a Cars DVD in to help reset the color intensities and focus... using the pause button to freeze a frame and set accordingly.
    Thanks again for your replies... it surely saved me some bucks and a number of late nights.
  • PFFB Mar 21, 2008
    Oh... and for anyone else who is reading this...
    If you're going to change your fluids, just take the CRT assembly out first. It's a 10 minute job (take them out of the front of the TV)... the connections are labeled pretty well that if I would have done before I started to drain the fluid, this would have been a 3 hour job from start to finish.
  • 2,326 Answers
I will try to help on this one.
Stay tune.
Posted on Mar 20, 2008
  • 1 more comment
  • Jaime Hernandez Mar 20, 2008
    Great info you are providing.
    Here's something you can try:
    If the coolant spilled on a circuit board assembly, I would suggest to remove that board and use a good amount of alcohol to clean it using a brush. The liquid coolant is very corrosive and even will become conductive if expose to a high voltage due to its oily and viscosity composition.
  • Jaime Hernandez Mar 21, 2008
    Just any rubbing alcohol will be just fine. Make sure you clean that circuit board really good. If the TV was fine before you added the coolant, then it should be still OK.
    Good Luck.
HOW DO YOU ADJUST RED,GREEN,BLUE TUBES
If your talikng about alignment that is done through the Convergence feature. If its the color balance youre refering too its most likley indicating that the CRT coolant needs replacment as that will make the red Tube dominate and wash out both blue and green colors untill they appear dull and dim.
Feb 17, 2011 | Philips 60PP9352 60" Rear Projection...
The colors look very weak. The green is weaker than the blue. Red seems ok. I have a philips 60 inch rear projection. It almost looks like a haze. The colors are not crisp. .
The TV has coolant in the CRTs that after years of use get cloudy. you will need to have a shop replace the coolant in all three, it is pretty involved so its best to have a trained tech. do it.
Oct 30, 2010 | Philips 60PP9202 60" Rear Projection...
I have a dptv305f phillips tv and the color is almost foggy and it seems like the colors are really green or red
Very common problem caused by the CRT coolant needing replacement. You can get the phillips CRT coolant kit at www.tvrepairworld.com which also comes with instructions.
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Philips Magnavox 9P6040 C102
Yes the coolant in the CRts need replacement. You can get the Phillips CRT Coolant repair kit at the following link which contains the coolant and instructions.
http://servicemanuals.vstore.ca/
Aug 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
Dull red color picture not very good
Replace the coolant in your CRTs. The blue and green are congealed and its making the red dominate. You can get the coolant kit at the following link which contains the CD with step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Jun 17, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips 60 in big screen
Sounds like the picture tube coolant needs replacing.. usually the blue tube..sometimes green or both
Dec 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
I have a Phillips maganavox Projection TV I believe it is model 9P6040CI and the color is dull and I believe the red is going or gone. I've tried to tune it but will not let me
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 02, 2008 | Philips 9P6040C 60" Rear Projection...
Philips 60PP9202 60 in. Help
You will need a service call by a qualified technician....
Red & green = yellow, therefore the blue CRT has a problem..T.
Feb 12, 2008 | Philips 60PP9202 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
229 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
