I need the legs that flip up for the back of keyboard
One of the legs that hold the keyboard at an angle busted and I can't find anyone that sells just that part. Any ideas? its for a Microsoft wireless keyboard #X09-50429
Re: I need the legs that flip up for the back of keyboard
You can make improvised stand for that any plastic material or buy stand as picture link. http://www.laptop-ergonomics.com/images/qwerty-Keyboard-Holder-LG.jpg
-Providing that the image shown is the tripod you own..., the top leg lock levers on each leg is designed to lock the spreader angle of each leg.
-If this is not holding the leg at the correct angle...., either you are putting more weight on it than it was designed to hold..., or the 'cam' on the various locks has worn.
-A 'stop gap' fix for this problem is to insert a very thin wedge between the lever & the leg tube..., thus providing a greater amount of pressure on the tube, (this would need to be done every time the tripod is set up).
-Replacement parts are not available for this tripod & they were not designed to be user serviceable ...., sorry!!!
Peter
You never know when you are going to need or want an easel to show off your art work, maybe your kids want to finger paint who knows they could be the next Van Gogh. Building a display easel is very simple and can be done in just a few hours.
You want to start with two pieces of wood cut to 2x82" these pieces will form the front legs of the easel. Using a table saw cut the tops of the wood to a 15* angle. Take a measuring tape and measure 78" from the bottom of the wood (up to the angle cut) mark this spot on both pieces.
Using a drill, drill a 3/8" hole through the widest side of the angle as a right angle to the cut. Repeat for the second front leg.
To make the back leg cut a piece of wood down to 2x81" long, using your drill, drill two 3/8" holes in the widest side of the wood. One hole should be 39" from the bottom of the wood and the second at 74" from the bottom.
Your art work needs something to sit on so to make the cross bar cut a piece of wood down to 2x47".
Now you are ready to assemble your easel. Take the front and back legs and lay them on the floor next to each other with the back leg in the middle. Rotate the front legs to the angle is facing the back leg and line up the holes. Slide a bolt into the hole and place a washer and a nut on the end, keeping it loose enough to adjust the angle. Stand up the easel and spread the from legs so that they are 45" away from the back leg. Tighten the bolt and you have the angle right and lay it back down.
To attach the cross bar, measure 38" up from the bottoms of the front legs find the center and drill a 3/8" hole in each and bolt the cross bar to the legs. To keep the legs from spreading too far you can attach a chain between the cross bar and the back leg. To do this you thread the chain through the hole in the back leg and tie it off. Attach an eye screw to the cross bar and loop the chain through it to keep limit how far the legs can spread to the angle that you want to work or display at.
If this is a 220 VAC dryer use a voltmeter at the wall plug. Chcking from common, usually the leg with the angled blade, to each of the hot legs, each with the straight blade. You need to have 110 VAC in both of these. If there is only 110 at one of the legs the motor will run but the element will not heat. If you find only one leg has 110 VAC try a new circuit breaker in the breaker box. If the breaker is bad it will appear to reset, but still not send current. If you have 110 on both legs check in the dryer for a burned off wire at the timer or element.
I would love to. First grab a
medicine ball and sit on the floor. Then lean back at a 45 degree angle raise
your leg and your feet off the floor and hold the ball with your hands stretch.
Rotate the ball and your torso as far as you can to the right and then to the
opposite direction without dropping your legs or your arms.
hello, Right-click your desktop and go to graphic options. It has to do with rotation so check the appropriate angle and rotate it back to normal. You may want to use the keyboard to navigate since it is quite confusing when using the mouse in such cases.
Open the dishwasher door and undo the two screws that secure the face to the counter-top. Open the kickplate and slide the diswasher out of it's hole. You should be able to easily access the back legs now. It may be easier to disconnect the drain and supply hoses (turn off the angle stop first) and flip the dishwasher upside down using a carpenter's level to make sure all your feet line up. Flip it over, reconnect, and reinstall.
Hey Steve, That keyboard is still available. If it still works, I would just tape a small block on the bottom of the keyboard near where the leg was. You may have to whittle an angle on it. Use electrical tape so your desk won't get messed up, or look around the hardware store for adhesive pads, rubber feet or ???? and save yourself around $80.00.
