Question about Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer
Frigidaire Affinity ATF7000 - E20 error code
We just got this washer. I washed a bath mat. Although I thought I adjusted spin speed down, apparently it was not enough, and we had little left of the rubber backing. Now there is water in the drum and it won't drain.
My husband is pretty handy, but isn't familiar with these washers. Is there anything we can do absent getting a plumber?
  • 3 more comments
  • jp1606fran Feb 08, 2009
    My washer keeps giving me a E20 error code and it doesn't spin the water out but if I turn it to spin it will then spin the water out is there some type of reset button?
  • bartleynorma Apr 06, 2009
    THANK YOU SO MUCH> YUCKIE STUFF AND MONEY>> I'm rich. I found almost 2 dollars in coins. Also the nasty stuff to.
    NO MORE ERROR: E20 code..
    DadtheFixer YOU ROCK..
  • Buddy Macdonald Feb 13, 2013
    This webpage is a big help also: ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995459236.pdf
  • Tim Schigur
    Tim Schigur May 20, 2014
    I have followed the suggestions and they were helpful in getting to the pump and drain. I found nothing really in the drain catch. The washer worked for one complete cycle and now the E20 reappears. Suggestions?
  • Tim Schigur
    I followed the troubleshooting suggestions and was able to check the pump and drain areas. I found nothing in the plastic catch device in the black boot/hose connected to the pump. After reassembly, the washer worked for one full cycle. Since, the E20 code has returned. Suggestions?
Thanks to the different postings on the net about a E20 error code I took apart my washer’s drain system ATF7000 to find. A pare of little girls underpants, one hair band, one plastic green gem, a golf ball sized wad of wrappers/stickers/???, and almost two dollars in coins. All caught up in the plastic strainer located inside the black rubber boot found on the bottom of the tub leading into the drain pump.
Here is how I did it: After emptying the washer of sloppy contents, I sucked as much of the water out with a shop-vac. I then turned the washer onto it’s left side gently using a couple of towels as a cushion (unplugging the washer and hoses first). From the bottom and back panel you can access the drain hose/pump/coin catch. With a pair of pliers you can remove the clamp holding smaller end of the rubber coin catch to the tub, with a Phillips screw driver you can remove the larger clamp of the rubber coin catch to the tub. From the back panel you again use your pliers to remove the clamp to the drain line, and finally with a Philips screw driver remove the two screws holding the pump to the bottom of the washer. Oh yah, do not forget to unplug the wire from the pump. Now pull the pump out with the black rubber boot still attached. Mark the orientation of the pump to the boot with a sharpie pen, and remove the last clamp. Now look inside the black rubber boot and gently remove the plastic basket inside, there you will find the treasures that just wasted the last hour of your time. Now reveres those steps, reinsert the half washed clothes, and enjoy your new machine.
Thanks again to everyone that has posted before me, otherwise I wouldn’t have known were to even start looking. I hope this helps someone.
Posted on Apr 22, 2008
  • 1 more comment
  • christina328
    christina328 Feb 16, 2012
    thx so much - took me and my nephew forever to get the clamps on and off but found a dollar bill - 4 qtrs - 7 dimes- 4 nickels and 5 pennies -never ever wash a rubber backed rug in these machines - what a flippin mess!!!
  • christina328
  • kdrew758
    kdrew758 Jun 17, 2012
    Switched to a few hose clamps to make life easier. Thanks for the note.
  • 5 Answers
I also have the Affinity wash machine. The tub was not draining and the E20 code came up. I checked the drain line and found nothing wrong. The problem was in the filter at the bottom of the machine. I accessed it through the large oval hole in the bottom of the washer. I laid the machine on it's left side and was able to get to the filter easily. You need to remove the large black rubber piece that connects the tub to the pump. Inside that rubber piece is a filter made of hard plastic, it pulls out through the large opening in the black rubber piece, remember how the filter came out it goes in one way, pretty obvious. Hold your nose, man it was bad. I found a Block Buster video card, about three dollars in change and a lot of lint. Put the filter back in the rubber piece and the rubber piece back on and your good to go.
P.S. be careful with the sharp edges on the sheet metal.
Posted on Apr 11, 2009
  • bradley04412 May 02, 2011
    Thanks so much for the extremely helpful directions. I found 8 coins, 3 dryer sheets, a few bobby pins, a button, a medal, and some other junk. Following your directions the whole process took less than an hour - I work slowly and am not so mechanically inclined. After lying the machine on its left side, I found it helpful to remove the back panel (6 screws) so I could have access via the oval opening in the bottom and the rear panel. Thank you. Thank you. Thank you. Thank you. Thank you. Thank you.
This is the exact solution. I just experienced error20 on my Affinity. Followed the steps- it worked. The filter in the rubber boot was clogged with an old drivers license, coins, a few bobby pins, and some lint. Removed. re-installed everyting, ran a spin cycle, and the remaining water drained. The only thing I would recommend is to never buy a front load washing machine. The technology is not worth the problems. Kudos to dadthefixer.
Posted on Jan 11, 2009
  • 14 Answers
I just fixed mine without taking the pump out. Just the black drain. Putting the clamps back on took almost 45 mins. Took my wife's help. I believe there is a special tool for the clamps but I used channel locks. Thanks for the help everyone!
Posted on May 13, 2009
  • 99 Answers
Sounds like you have a rubber clog, at the bottom of the unit, near the motor you will see all your hoses. try to disconnect these hoses and unclog the the rubber. good luck.
Posted on Mar 20, 2008
I read these posts and then dove in. I agree, the sheet metal is sharp and I bled for quite awhile when I cut my elbow. I have little room, so I did this without laying the washer down; access via the large removable back panel. Other than that, I proceeded like the others and found change, junk, bobby pins etc. Since I had the hoses loose I also cleaned out the inlet filters to avoid future problems...
Thanks!!!!
Posted on Aug 07, 2010
This post saved us a call to a repairman. I found a Purell washer sheet, and $0.37. As well as 20 bobby pins. Thanks!!!
Posted on Dec 15, 2009
    New Friend:
Great advice. I used the wrfish method and came in from the tub side (when the washer was on its left side). It was easy to unscrew the hose clamp. In the filter basket I found a b r a pad (main culprit), paperclips, hair clips and $2.37. It took me less than 1/2 an hour to complete the job.
Posted on May 11, 2015
Error code 20 means the pump inlet is plugged. The manufacturer and their servicing dealers say there is no such thing as an error code 20. Do you know why? Because it is a way to have the consumer call a service guy out and pay through their nose just to have the tech clean out the **** screen on the inlet side of the pump. The following link shows part # 40 (the filter). Remove it, clean it, re install it and the pump is now able to **** freely, like new.
I did almost the same as Dadthefixer but I only removed the bellows from the tub at the big end and gently pulled the screen out.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5156812&diagram_id=28906720#d28906720
Posted on Sep 28, 2012
Thanks for the info! My washer popped the e20 code after a couple years of usage. Flipped it on its side and removed the black rubber drain and pulled the filter housing out. My girlfriend found this inside.. , 1, 1gig sd card, 2 quarters, 3 nickels and 3 pennies, i bobby pin, and random pieces to what looks like a mechanical pen amongst a TON of dog and human hair... It was like a demented surprise inside. Thanks to all for the info!
Posted on Dec 04, 2011
    Problem Solver:
  • 11 Answers
Kathy
Sorry you had this grief. Rubber backed rugs can not stand this kind of aggitation. You should always hire a Certified Master Rug cleaner, or in this case as it is just a bath mat, wash it flat in your driveway with a soap and a care brush, rinse it off fully, then put into your washer for the final spin to speed up the drying time
Stephen "Dusty" Roberts
Certified Rug Master
www.luvarug.com
Posted on Feb 13, 2011
Holy ****! Thank you to everyone who posted about this problem. I tried to wash a small wool rug and the machine threw a E20 code. I thought for sure I had done it. Turns out after following everyone's instructions to get to the filter there was a freaking WHOOPEE CUSHION stuck in the plastic filter. Along with a dozen or more bobby pins and hair clips and a hand full of rubber bands. I hear by ban whoopee cushions from this household! Anyway, my girls don't need them, they make enough sound effects on their own ;-)
Thank you to everyone who posted. You guys rock!!
Posted on Mar 26, 2010
  • onecanadianb Feb 22, 2011
    Thanks for the help...it work! It sucked in the way I lost a pint of blood...but did manage to get $15.50 for the effort and did not have to call a plumber!
Thanks you all soooo much! Your answers were all so helpful and I am doing laundry again!
Posted on Mar 11, 2010
Error code 20 on an affinity frigidaire
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 23, 2012 | Frigidaire Affinity ATF6000F Front Load...
E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
Dec 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Error code ESE
This is a problem whith your speed controll replace the the speed controll in the bootom of the washer
May 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
May 04, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer Logo
11,827 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
