Question about Panasonic TH-37PX60U 37 in. Plasma HDTV
Panisonic TV all locked up
Our TV is completely locked up. We have not put parental locks on it or anything like that. We cannot change the TV/Video input, or anything else, either through the controler or directly on the TV. All we can do is turn the TV on and off through the remote or TV. None of the other buttons or inputs will work, either through the TV or remote. It is complete locked on one setting! My tv is locked on one setting. None of the buttons on the tv or remote is working.
  • alvinb Mar 20, 2008
    Good morning,
    i just plugged in my tv. it is still locked. it has been unpluged for 11 hours. i am now going to try to keep it unplug for 24 hours. hopefully it does the cold boot. i will post again tomorrow, but if work holds me ... i will post in 2 days. please help me =). thank you!
    Brigadier General:
  • 6,966 Answers
Any other developments (or lack thereof) after our Live Chat?
Regards.
Posted on Mar 20, 2008
  • Louie  Role
    Louie Role Mar 21, 2008
    Hi again Alvin,
    I copy that the reset was not corrective. Alternately, would you pls check the following settings/features of your TV (if present):
    1. Input Skip: If an input's label
    is set to skip, that input isn't selected when toggling through inputs with the
    TV/Video button.
    2. Lock: The Lock function has four
    settings to block viewing of particular channels or inputs. You create a 4-digit
    password that's required to bypass the lock. The available settings are:
    • Off: nothing is locked
    • All: all channels are locked
    • Game: channels 3 and 4 and
      the video inputs are locked
    • CH: locks specific channels
I want to delete the parental control and have no code number please help many thanks
  1. Open the Parental Locking Settings screen (MENU - SETTINGS - PARENTAL LOCKING). Press OK.
  2. You will be prompted to enter your PIN.
  3. Use the ARROW buttons on your remote control to select TURN OFF LOCKING, and then press the OK button.
  4. Select RESET ALL PARENTAL LOCKS, and then press OK.
  5. Select RESET ALL PARENTAL CONTROLS. Press OK. A message appears asking if you want to reset the 4 digit PIN and stop using parental locks.
  6. Select RESET and press OK.
The set-top box closes the Parental Locking Settings screen and returns to the last channel tuned.
The Parental locking option in the SETTINGS screen shows parental locking as completely turned off (no lock icon in the Parental Controls box).
Apr 04, 2018 | The Video Game Consoles & Games
My remote will not work and the parental controls are locked on the set, so the TV will not do anything.
  1. try to clean it or change the battry or quartz 455 mhz
  2. buy a new universell rc and put the code of your tv
  3. good luck
Dec 06, 2010 | RCA 32V550T 32" TV
T.V. LOCKED
Please view this FixYa Tip which outlines the procedure for removing the parental lock when the screen is locked on the Apex TV.
Thanks for using FixYa.
Mar 18, 2009 | Apex Digital AT2702 27" TV
How To Remove A Parental Lock Without The Remote Control?
That is called Hotel Mode. Look in your instructions for help.
Enter the service menu and select Hotel Mode to switch it on or off.
Apr 15, 2017 | Philips Magnavox MT2501C 25" TV
Parental lock
1) Try P-Lock and pasword "0000"
2) Turn TV off and unplug from wall outlet for 30 seconds
3) Check p. 9 and other relevant sections of your user manual.
4) Call Insignia at 1-877-467-4289
May 26, 2008 | Insignia LCDTV26 26 in. Television
Hacker code maybe
Hi Karyne1975,
Initially, I would venture that the Parental Lock has been engaged and was set to the lowest level meaning the TV will not allow any channel to be displayed, they are all blocked.
To remove the parental lock, proceed to the Main Menu display, press on LEFT or RIGHT arrow key till Parental Guide Setting is highlighted. Before you can access, an entry code is required. The factory default is 1225 (that is if it has not been changed). Upon gaining entry, press on UP or DOWN and/or LEFT or RIGHT arrow keys to turn any entry in the MPAA-Rating and/or the TV-Rating to show U (unblock). Additionally, it may also be necessary to turn the RATE SETTING to OFF. Exit.
To my knowledge Parental Lock is not disengaged by full hard reset or unplugging from mains.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 26, 2008 | Apex Digital PF3230 32" TV
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
u unplug it for wile then plug in hold down power for 20 sec see if it resets it
Jan 29, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
DVD parental lock
I have a GE 13TVR62 (with a problem listed here). I've learned that the Parental Lock Settings are changed by using the Remote Control. Usually the actual Settings are changed by pressing the Up or Down or Left or Right Arrows to make the Change; while the Parental Lock is Highlighted on the Menu.
Dec 22, 2007 | GE 13V110TD 13 in. TV/DVD Combo
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
567 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
