Question about Whirlpool LER5636P Electric Dryer
IT RUNS BUT DOESNT HEAT
I have a whirlpool LGR6620PQ0 IT WONT HEAT ' WHAT IS THE PROBLEM
  • 1 more comment
  • Anonymous Jul 23, 2008
    I have a Whirlpool gas dryer model #LGR 6620PQ0. I put it on automatic dry at night and it was still running the next morning but now there is no heat. It is only 2 years old.
  • Belgaron Oct 02, 2008
    I checked and even bypassed the sensors.........heat is intermittent. possible burner/sensor problem?
  • khorn Feb 04, 2009
    Same problem. Put it on auto dry and found it still running three hours later. Runs fine, it just doesn't heat up. Also only two years old.
I replace the Fuse, Thermal (Part # 3392519) and now works perfect!
Posted on Mar 26, 2009
    Scholar:
  • 178 Answers
It's either a heating element or thermostat gone bad. This link will help you locate what to look for. http://www.partadvantage.com/store/categories/wp/LGR6620PQ0
Posted on Mar 20, 2008
6ya staff
SOURCE:
Dryer wont heat
The problem is likely the thermal cut-off and/or the high-limit thermostat if the dryer runs but doesn't heat. Verify this by bypassing the thermal cut-off and the high-limit thermostat. Click on the link below for the detailed troubleshooting.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 18, 2011 | Whirlpool GEW9200L Electric Dryer
Dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Mar 02, 2010 | Whirlpool Dryers
Whirlpool gas dryer makes a lot of noise
This sounds like the support rollers are either loose or worn out.
Turn off the power, shut off the gas, pull the unit away from the wall carefully, and remove the back of the dryer.
Look around the perimeter of the drum and you will see the rollers. There should be 3. If they wobble or the rubber on the rollers is worn down, they are bad and need replacing. While you're in there, inspect the motor, belt, and drive assembly to be sure it's solid.
An appliance shop or parts outlet can usually provide these parts for your unit.
Jan 28, 2010 | Dryers
Dryer runs but doesnt heat up
On a Whirlpool, it has been for me the coils are broken...it can be fixed by undoing the belt, 'popping' the top pnl up with a screwdriver, lean the front pnl down then move the drum forward to get to the coils. You MUST use a crimp type connector as these are nickle wire and won't solder easily. Saves a lot of money and will run forever. Definitly unplug it first! Duh!
Dec 10, 2009 | Whirlpool LER5636P Electric Dryer
Microwave has power but wont heat food
Nothing to do with programing if it doesnt heat you have a bad magnaton or a bad capacator. I work on panasonic microwaves every day.
Sep 27, 2009 | Whirlpool MH7140XF Microwave Oven
Dryer model LER6620PQ0 dryer runs, but will not heat
If drier runs and doesnt heat, it can be one of two things. 1)The over temp. th/stat has activated. Possibly it can be reset. or 2)the actual element is faulty, which would need replacement.
Sep 21, 2009 | Whirlpool Dryers
Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
Mar 11, 2009 | Whirlpool LER5636P Electric Dryer
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Dryer wont start
Possible door s/w or thermal fuse. If its blowing thermal fuses with a clean and avg vent run check the relay, cycle unit with no heat fuction if the heat still comes on replace the relay board. Call your local servicer.
Mar 16, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
556 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
