Question about Jensen VM9410 Car DVD Player
Jensen 9410 will not load or eject
Brand new unit out of the box will not load or eject. screen displays "eject" and "loading" and it sounds like there is a motor running. please help!
  • chevelle300 Dec 25, 2008
    i can hear hum like it wants to take cd or dvd but will not go into radio dvd does not work either can any one help with this the radio wporks fine and screen come out properly but cant play cd and when turned off and turned back on it comes in a 17 volume does anyone know this one too thanks mark
I had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
Posted on Apr 03, 2008
I bought a truck with a Jensen UV10 installed that wouldn't load or eject discs. I took it out and disassembled it until I found the problem. There is a grey rubber roller along the length of the disc slot which pushes and pulls the disc in and out. On the end of that roller shaft there is a small gear which fits against a larger white gear. The tab of plastic on the outside of the assembly that is supposed to keep the gears aligned is not secured very well, and can allow the large white gear to slip into the wrong spot and loose engagement with the roller gear. I used a small tip of a needle as a shim between the metal housing and the plastic tab so that it could not move beyond parameters. Use a small dab of epoxy to keep it in place. Works fine now.
Posted on Sep 13, 2012
When i pop out the screen it only works when its tilted way down seems like the ribbon is loose how do u fix it
Posted on Nov 11, 2008
2 Suggested Answers
  • 3422 Answers
SOURCE: jensen 9410 will not load or eject
Try Hard reseting your player first by unplugging all the cords for 30min and then plug it back.
I will be posting more solutions...
Toshiba REGZA won't play DVD. Shows "disc loading" then goes to wide screen mode, but then ejects the disc. Whats up?
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2014 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Apr 03, 2008 | Jensen VM9410 Car DVD Player
CD does not eject from my VM 9410 Car DVD Player
it probably got jammed in there what you can do is unplug the power source and replug it back in a brief power push should eject the disk. make sure you have your unlock codes as the unit may think it got stolen if you undo the power. if that does not work to get it fixed around $89 bucks Thanks and please rate
Aug 18, 2009 | Jensen VM9410 Car DVD Player
Magazine won't eject
HI, the load motor has failed in your changer and , you will have to replace this. its part of the loading dock assembly and it turns all the gears associated with the loading and playing procedures.
If you are hearing continuous clicks, this will be the reason for the failed motor.
May 21, 2009 | Jensen XCH6RF 6-Disc CD Changer
Jensen 2006 7" indash touch screen: CD player wont work
Try a lens cleaner . If that doesn't work then it would have to be repaired.
May 07, 2009 | Jensen MP7610 CD Player
Unit will not play or eject discs
try to repair it agin.
this time i think you have to change only loading belt and optical lence.
are you technicaly sound.
nuwan.
Nov 10, 2008 | Sony DAV-C770 System
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Upside down dvd inserted
FYI - This might damage the unit, but if you really need to get that DVD out then you can try this at your own risk!
Try unpluging the unit, then plug it back in and press the power button and a split second later press the eject button. This all needs to be done quickly otherwise the unit will try to load the disc.
Or
You can try letting the unit load the DVD. When the unit says "Please eject disc. Playback feature may not be avalible on this disc," press the eject button.
Apr 01, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Jensen VM9511TS AM/FM/CD/DVD/SD
you may have to open the unit up and manually turn the unload and load gear to eject the DVD from the carriage. The load and unload gear is a round gear located under the DVD carriage and is attached to the load and unload motor
Sep 20, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Wont load or eject
I have the same problem! tuner works just fine. I cant access the dvd mode. i can only access tuner, video input, and rear cam. Ive tried different cds and dvds and it did not help. Also it seems like the ejection mechenism is running continuesly.
Jan 30, 2007 | Jensen VM9410 Car DVD Player
Jensen VM9410 Car DVD Player Logo
605 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
