Question about Jensen's VM9312 Car DVD Player
Quit working I've only had this unit for about 2 months today i stopped at the gas station and turned the key backwards so it would stay on then when i started my car back up it beeped a few times and theres nuthin but a blank screen the only button that lights up is the red power when i manually shut it off the screen doesnt even go in and it wont play, eject the cd or anything it beeps like it's supposed to but thats it the radio wont play either.. Any help would be appreciated because i dont have a box or receipt for warranty.. Thanks Daryn
  • srobles07 Jul 28, 2008
    ill put a disc in my in-dash player and it will go half way in, while halfway in the player trys to read the disc two times then shoots back out not able to play anything. i dont know what to do...if thge player is DONE or can be FIXED????? i payed alot of money for it im just lookin for a solution.
  • Anonymous Dec 28, 2008
    my screen will come on for a second and shuts off
Check your car's fuse, if it is burned it means you might need a more powerful one. Mine has a 15 amp and works fine.
Posted on Mar 20, 2008
SOURCE:
Engine won't stay running - only will start with starting fluid.
VERY COMMON problem with gas engines.
I recommend starting all your gasoline using machine ever month or two. Let them run a few minutes. Same with cars/trucks.
Start you r car/truck every couple months and drive forward and backward several feet as well.
If you have a gas shutoff valve, turn it off and run engine till all gas is out of carb before storing.
Gas turns to a hard lacquer is sitting too long. remove air cleaner covers, Pour some real good (strong/thorough) carb cleaner in carb and leave sit over nite. If that doesn't work, do it another nite. If not working yet, you may have to take carb off and open it up. Be careful there are little tiny parts in there.
Apr 03, 2016 | Garden
Gas gauge quit working, now car won't start
Sounds like you dont have any power going to your fuel pump. You will have to drop your tank and with a light tester check the red wire for power. If you cant tell with one is the red wire it will be the secound wire going into the plug. If you dont have any power there then make sure your fuses are good. You will need help with this because it is very had to reach the key switch and check the wire the same time. It is on a relay switch and only stays on for 5 secounds. Good luck.
Nov 25, 2012 | 1998 Volkswagen Beetle
WMA stream on a constant loop for my favourite radio station
Since other stations worked perfectly, perhaps the other station was streaming a loop.
Otherwise try this: Support Cobra Electronics Corporation
Mar 21, 2017 | Cobra Radio Communications
2000 Chevy Lumina wouldn't start at gas station out of nowhere...security light and volt light came on.
to reset security you'll ned to do the 10min key with ign. on for 3times after each 10 min turn key off briefly then back on without trying to restart after 30min or three 10min ign on cycles turn off key briefly then the car should start
Sep 02, 2012 | 2000 Chevrolet Lumina
My 1999 Buick Park Ave started hesitating and the CEL would flash. I would back off the accelerator and it would smooth out and the light would go off. About a month ago the car died while I was driving it...
Have you tried the reset method? Turn key to the ON position and leave it there for 10 minutes, or until the security light goes off. Then turn key to off, and back to on and start-see if it starts after letting it sit for a few minutes like that with the key in the on position.
Apr 11, 2017 | 1999 Buick Park Avenue
I PURCHASED A MAGNAVOX TB110MW9 CONVERTER BOX FROM WALMART. I HOOKED IT UP. IT SCANNED THE CHANNELS BUT IT KEEP SAYING NO SIGNAL.
I have a Magnavox TB110MW9A converter box that has worked fine for the last 8 months. Now you turn it on, the light blinks 31 times, stays on and there's nothing on the screen! The remote does nothing. (yes, I put new batteries in)
Jan 25, 2009 | Televison & Video
Low Fuel Light is BROKEN!!
and just went a wee bit too far -- 188mi. and stalled about 2 mi from the gas station. Finally put my AAA membership to work! Does anyone have any good suggestions on how to ENSURE the light is Activated while I go to replace/fix it?! Do I LITERALLY have to run my tank dry and HOPE that the circuit isn't damaged on the sender?!? Last time I monkied with the dash lites it was very easy to replace the bulbs BACKWARDS and therefore not get proper continuity in the circuit (probably what I did). Dunno.....just want to do this as easy and quickly as possible -- I've run the tank dry for THE LAST TIME!!! Too bad our dash's don't do a pre-start diagnostic, like most modern bikes do nowadays! ,Mine quit working for a couple of months and I ran out of gas once, that's when I went to the Trip-o and used it for refuel warnings, i.e. 130 miles start looking for gas. It magically started working again about a month ot 2 later, but I never trusted it. Nope, I use the 'ole mileage method, way more realistic and trustworthy I went 174 miles when I ran dry. That was with the Rene #2 chip and my complete setup driving in traffic and freeway, so free use of the throttle. My light normally came on ~140 miles on the Falco. 120 on the Tuono. ,,,
Nov 10, 2008 | 2005 Aprilia SL Mille Falco
Car won' start
Sounds like baD FUEL TO ME.
Jul 29, 2008 | 2002 Pontiac Grand Am
Jensen's VM9312 Car DVD Player Logo
504 people viewed this question
Top Jensen's Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
