Question about GPS
Roadmate 360 gps freezes after about 1 hour, can then only unplug and wait 5 minutes, plug it in and in another hour, same thing happens every time I go on the road. whats the problem?
  • sarjonmiller Mar 20, 2008
    I paid $599.00 for a magellan roadmate 360 3 years ago, and didn't get to use it until after the warrenty was expired, when I did try to use it, It would freeze up after only about 1-2 hours, I couldn't turn it off, only unplug the power cord and wait several minutes, and plug it in again, It would work for about another hour, and the same thing again, I can get no help from magellan whatsoever, I will never again buy magellan, a big piece of junk.
    There is no upgrade for it according to the magellan web site.
Have you tried upgrading the software on the unit?
Posted on Mar 20, 2008
SOURCE:
My caller id is not working on my at&t 974 phone
Same thing happened to me. Here's what I did: 1) Unplug phone. 2) Remove backup battery. 3) Wait at least 5 minutes. 4) Plug phone back in and insert battery.
Step 3 is important. I only waited about a minute the first time and the problem remained.
Jan 07, 2014 | AT&T ATT-974 Corded Phone
I want to update my Magellan RoadMate 360. How
Usually it takes a usb cable that plugs into the device, and you have to go the manufactor webiste.
Nov 16, 2009 | Magellan RoadMate 360 GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
I heve deleted all internal files so its not
there are a few things you can do here. go to the magellan site and download the latest update..it will not repair your unit but it will get magellan to fix it free..the only reason i even tell people this is because magellan gps are to easy to enter the boot menu and screw their unit up
#1 magellan will repair or replace any gps that were rendered inoperable do to their update, i just wouldn't tell them i unplugged it accidentally or on purpose or what ever happened... i would call them 1st before moving and coping files around, but i will help you if you decide not to call magellan. make sure you download the update before contacting them.. i would do that 1st because they check to see if you downloaded the update. here is the support hours and phone #
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
Aug 16, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Broken power socket on Roadmate 360
Yes you have to change the dc jack in it.. It took me about an hour..
Jan 07, 2009 | Magellan RoadMate 300 GPS Receiver
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Xbox360 live + need for speed carbon
why this is happening is because your hard drive may have a corrupted file inside that game but your not screwed i have a solution :) while it is a crappy process you have to call the support center 1-800-4myxbox and tell them exactly whats happening they should tell you to go to the dashboard then system hard drive and you type a button code much liek a cheat which will let them observe your consoles memory code as you play so when you turn it on and it freezes they see what code is making freeze and delete it. i had to do this but when it froze again my console got the three red lights lets hope this doesnt happen to you. i have some things to try at hom though try unplugging your ethernet cable and all other cords then re-plugging them back in. if that doesnt work try re-setting your network connection, unplug modem and router for 3 minutes then re-plug in and let sit for another 3 minutes if this doesnt work call xbox support.
Jan 23, 2008 | Microsoft Xbox 360 Console
Screen Freezes
register your unit on the magellan website and there is a firmware update and it will solve your problem
Dec 18, 2007 | Magellan RoadMate 700 GPS Receiver
GPS Logo
46 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
