Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
I have the same problem and went through the steps till "reset catalog"..
But after giving the reset catalog command I got a message "Unable to reset the Winsock Catalog.
Access is denied."
Whatcan be the reason. I don't have much acceses enabled in Internet options as the laptop is official.
  • 35 Answers
Are you talking about the router ?
Posted on Aug 29, 2008
6ya staff
SOURCE:
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
C8180 oxc 18a0306
This is most common error in inkjet HP inkjet printers.But you are not mentioned model number, any how try this:
Step 1.
> Remove all the supplies like print heads & cartridges..
> Remove USB or any other device connectivity from system.
> Switch off the printer.
> Wait couple of minutes.
> Switch on the printer, wait till printer asked for the supplies.
> Insert supplies as per specified messages.
> Check for ready mode, insert data cable & give print command.
>>>Check.. no message.. END.
Step 2:
> If problem remain same..(I will suggest for tech guys)
> switch off the machine, remove all the supplies
> Open printer side covers.
> find out the CMOS batter mounted on formatter ,remove it..
> wait couple of minutes..
> with out CMOS batter do the above said step 1 process.
> check.. I hope it will resolve this issue..give print command.. verify..once its resolved CMOS batter has to be installed.
> Switch off the machine,
> insert CMOS battery,
> do again step1 process,,..
......END....
Best of luck...Thanks for choosing FIXYA
Dec 23, 2011 | HP Photosmart C8180 InkJet Printer
Error code 0xc19a0035
Step 1.
Step 2:
......END....
Dec 09, 2011 | HP PhotoSmart Office Equipment & Supplies
I am getting the following error message with the Seagate GoFlex 2TB wxternal hard drive after it fell a short distance10 inches. my computer recognizes it and i can see all the files but cannot access...
Open up a command prompt with the command Windows key+R or go to Start>Run...> and type the command "cmd" and press Enter. At the command prompt window, type the following command:
"chkdsk X: /f" Where "X" is the drive letter of your external device. This command will scan your drive for any virtual errors that may have occurred, and attempt to fix them. If this does not solve your issue, it is best to call Seagate for a replacement of some kind
May 09, 2011 | Computers & Internet
My laptop is showing that I have excellent connection with my wireless, but wont connect to internet, ran connection diagnostics and it said problems with Winsock Provider Catalog, any help please....
To repair the Winsock catalog you will need to reset it back to its default state.
Instructions
  1. Click "Start" and type "CMD" in the search box. Press the "Ctrl," "Shift" and "Enter" keys simultaneously. This action opens a Windows Command Prompt with administrative privileges.
  2. Click "Yes" on the permission dialog screen and the Windows Command Prompt opens. You should also see "Administrator" at the top of the window.
  3. Type "netsh winsock reset" next to "C:\Windows\System32" and press the "Enter" key.
  4. Restart your computer after you see the message "Successfully reset the Winsock Catalog."
After executing this command, you may need to reinstall the software for your network hardware.
Jan 14, 2011 | Dell Computers & Internet
I just bought a used netbook that was set to manufacturer conditions. It says I am connedted to my droid wifi but I cannot go online. When I run the diagnostics I get a message that says Windows has...
Please follow the steps below to repair or to reset Winsock for Windows Vista users:
1. Click Start Menu ,type cmd in the Start Search box, right-click cmd.exe, click Run as administrator, and then press Continue.
2. Type "netsh winsock reset" (without quotes) at the command prompt, and then press ENTER.
Note If the command is typed incorrectly, you will receive an error message. Type the command again. When the command is completed successfully, a confirmation appears, followed by a new command prompt. Then, go to step 3.
3. Type exit, and then press ENTER.
Thanks and regards,
Jitha.G.J
Dec 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
My brother mfc 495cw keeps giving an "unable to init." error message. [email protected]
Hi. my machine model MFC 495 CW. I did any step but my machine till show up unable to Init. 4 F. please can you help me about that. thanks you very much
Tien
Sep 07, 2010 | Brother MultiFunction Center MFC-440CN...
My TI-84 Plus won't graph two functions at once. Only one equal sign highlights. My math teacher doesn't even know what to do and I really need two functions to show on one graph.
Turn the satistical plots OFF
Press [2nd][Y=] (STATPLOT). Select or enter 4: to execute the command [PlotsOff] [ENTER]
Clear the lists (statistical lists)
Press [2nd][0] (Catalog]. Press [PGRM] C. The cursor jumps to the first command in catalog that starts with C (The greek letters in names do not matter). Scroll down a bit to reach the command [ClrAllLists]. Select it and press [ENTER].
Try your graphs again.
If you still have problems, just reset the RAM:
Press [2nd][+] (MEM). Press 7 to select [Reset] then [1:All Ram][2:Reset]. Press [Clear] to erase the Ram Cleard message.
Now you should be able to draw the graphs.
Hope it helps.
Thanks for using FixYa.
Nov 19, 2009 | Texas Instruments TI-84 Plus Calculator
Connection dropping every 2 hours and router resets
For these commands, Start, Run, CMD to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
If that doesn't get the job done after a reboot, set it to automatic IP addresses, reboot, then post this:
Start, Run, CMD to open a command prompt:
IPCONFIG /ALL
Right click in the command window and choose Select All, then hit Enter.
Paste the results in a message here.
Jun 25, 2008 | 2wire 2700HG-B Router (2700HGB)
Firewall settings
This usually happens due to missing or corrupt SharedAccess reg key, which represents the Windows Firewall Service.
Resolution
Download sharedaccess.reg (for Windows XP SP2 only) and save to Desktop. Then double-click the file to merge the contents to the registry. The Services entry will be created. Restart Windows (mandatory step, otherwise the following NETSH command will display an error message).
After restarting Windows, run the following from Command Prompt (cmd.exe)
NETSH FIREWALL RESET
Launch firewall applet from Control Panel, and then configure your Windows Firewall settings.
If nothing helps, as a last-resort solution (before reinstalling Windows XP Service Pack 2), give these two commands a try. Click Start, Run and type:
rundll32 setupapi,InstallHinfSection Ndi-Steelhead 132 %windir%\inf\netrass.inf
Restart Windows, and then run this command (from Command Prompt):
Attempt to start Firewall applet. Start the Windows Firewall service if prompted.
Apr 21, 2008 | Microsoft Windows XP Professional With...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
51 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
