SOURCE: amp turns on and stays on but no sound
are you shure you not connect the amplifier in a wrong connection ...B+,GND,ACC.....ok...then checkif the speakers wires stay in good condicions, some times when we intalled the spk wires for the border of the doors a few times skrewered too.check if it hapen. another ....check if the terminal spk is not going at ground whit the chasis another to....4 ohms per channel ,anny voice coil spk burned...in short. good look.
SOURCE: Green light (protection mode) on, NO red light (ready)
double check your wires aren't shorting out or power or remote wires aren't grounding. check if speakers are blown with nine volt battery
SOURCE: My amp has no sound It is hooked up right and has
Contact Eric @ Capital Audio & Electronics Repair 850-339-1130 we repair all brands & models
SOURCE: what does the red and green light mean ???
red and green light? there is most likely a protection and a power light. The red I assume would either be a protection light or a clipping light signal. Does the amp kick off then these lights kick on red then to green?
4-Way
5-Way
6-Way
7-Way
Green
Yellow
Brown
White
Red
Blue
Purple
Right Turn & Brake
Left Turn & Brake
Tail Lights
Ground
Backup Lights
Electric Brakes
Auxiliary Power
Green- Right Turn and Brake
Yellow- Left Turn and Brake
Brown- Tail Lights
White- Ground
Red- Reverse (Back Up) Lights
Blue- Electric Brakes
Purple- Auxiliary Power
It sounds like your green and yello wires are shorted together somewhere along the length of the harness. I would check the wires on the trailer first. Easier yet, if you have another trailer to connec or access to another to use for testing, connect to it and see if the problem repeats; if it does the trouble is in the vehicle's wiring.
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
