Question about Panasonic Toughbook 28 Notebook
Toughbook 28 I have 2 toughbook 28s. one is a 600mhz the other is an 800mhz. I took my hard drive from my 600 and put into my 800, and it will not boot. it bbots to the start windows normally/safe mode screen, and when i select any of the options, it boots to another screen, then reboots before I can read what it says. any suggestions?
  • 37 Answers
In Toughbook computers there is an option to lock your hard disk(the contents of the HDD cannot be accessed when it is connected to any other computer than its native one). First, you should check that by connecting the HDD in its native computer i.e the one having 600mhz. Press F2 when you start it up and chnage the option to lock the HDD in the bios setup screen.
There is one more problem. The operating system installed in the HDD is having the hardware configuration of your CF 28 600mhz. So, it won't work in a computer with different hardware configuration.
Hopes this will provide you with the cure for your problem
Posted on May 11, 2008
    Genius:
  • 3,587 Answers
Sure...use F2 when you start it up, and make certain that drive is listed on the bios setup screen..and also is in proper boot sequence order..you may need to revise the bios to see that other drive..this is not always a simple matter
Posted on Mar 20, 2008
SOURCE:
Bios password
On most Panasonic Toughbook models, when you turn on the power and immediately press the "Esc" key, then a new startup menu will be shown.
Simply choose "CD-ROM Drive" as the boot device and make sure that you have previously inserted a CD-ROM in the drive and then the Panasonic Toughbook should startup or "boot" from the cdrom
instead of from the internal hard disk drive.
I have attached a photo
Good Luck and Regards from:
Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989
Jun 17, 2012 | Panasonic Toughbook CF-29 Notebook
Is a Panasonic CF 27 Toughbook able to have Windows XP installed on it or would it create conflict? Presently, it has Windows 2ooo installed.
This is taken from Microsofts website directly...
These are the minimum requirements for basic functionality. Actual requirements vary, depending on the system configuration and the programs and features that you choose to install. If you are installing Windows XP over a network, you may need additional available hard-disk space.
The minimum hardware requirements for Windows XP Home Edition are:
  • Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended)
  • At least 64 megabytes (MB) of RAM (128 MB is recommended)
  • At least 1.5 gigabytes (GB) of available space on the hard disk
  • CD-ROM or DVD-ROM drive
  • Keyboard and a Microsoft Mouse or some other compatible pointing device
  • Video adapter and monitor with Super VGA (800 x 600)or higher resolution
  • Sound card
  • Speakers or headphones
And from what I have seen (THANK YOU for the model #) your system SHOULD be able to run it at bare minimum.
Aug 06, 2010 | Panasonic Toughbook CF-27 Notebook
My Panasonic Toughbook T2 was shut down properly and kept for about a month. now it does not boot. Even inital BIOS check function is not performed. Though HDD movement can be heard. Checked RAM by...
Is there any chance the video output is switched to feed the rear VGA connector? ie the screen is black due the video being routed away from the screen. Try hitting F5 key.
Can you hit the Delete key to try and enter the bIOS screen? (it may be another key such as F1 or F2. See your Toughbook manual)
Can you have someone make you a bootable USB thumb drive and try booting up with that?
Its also possible that the hard drive has failed, but usually the BIOS POST check will initiate and indicate a failed hard drive or bad RAM etc
Can you remove the 2.5 inch hard drive? Usually its accessible under a removable panel under the laptop.
Feel free to ask more questions.
Cheers,
Steve
PS have you tried the discussion forums on the Panasonic website?
May 03, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
During bootup, makes pong sound then goes to white screen, no cursor. Apple g3 14" running 10.4
Its a hardware failure! Usually a hard drive failure.
If you have the software Mac Tools, put that cd into your drive and boot the mac tools software to test the hard drive.
If the hard drive passes, then the software is corrupted and need reinstalltion.
Please write me back to tell me if this helps
Mar 19, 2010 | Apple iBook G3 14" 800MHz Mac Notebook
I GOT THIS MESSAGE TODAY PXE-E61 MEDIA TEST FAILURE CHECK CABLE WHEN I TRIED TO BOOT MY ACER ASPIRE 5630 THIS MORNING. IS THERE A QUICK FIX FOR THIS? EXITING BROADCOM PXE ROM OPERATING SYSTEM NOT FOUND
It is trying to bbot up using network boot because it cannot find OS on the hard drive, you can turn off the network in the BIOS setup page, but more likely you have problem with the hard drive or the OS is corrupted.
Nov 04, 2009 | Acer Aspire 5630 Notebook
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic Toughbook 28 Notebook Logo
222 people viewed this question
Top Panasonic Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
