Question about Refrigerators
Computer in door is making a loud popping noise,all controls are flashing thier lights
  • 1 more comment
  • pattiburk Mar 20, 2008
    Hi
    Thank you the model number is 12568AES and the serial number is 10982768JC. I will get sombody in to repalce the board,but if you could send me one that would be great.I leave in a very rural area of Montana and is difficult to get good help to do these jobs
    HI Never mind ordering this board,I have contacted a guy who will get the board for me and install. Thanks for your help
  • mkehler May 25, 2008
    I am having the same issue with my fridge. Kenmore Elite - Bottom Freezer - Model 77532.
    President:
  • Refrigerators Master
  • 2,651 Answers
Assuming this is a maytag ice and water dispensing 3 door refrig correct???? you need an new high voltage board located o back wall of your unit, without model i cannot look up for you. Happy to if you supply model. its easily replaced, but needs to be programmed to work, instructions come in kit but can be a little tricky to follow the first it me, go slow and youll get it.
Posted on Mar 20, 2008
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Started flashing and making popping noises, but still heated ok. Then stopprdheating and just makes a loud buzzing noise
The magnetron is most likely the problem, it heats the food and is the heart of the of the microwave oven, if it was followed by unusual odor more noticeable when you open the door that would confirm it, but that is not always the case. The cost to repair would exceed the cost of a new one
Jan 19, 2011 | Thermador MBBS Microwave Oven
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Opener wont open makes clicking noise
Your opener has been hit by lightning or power surge.
If it's not too old you can replace the 'back board' (the computer board on the back of the opener.) Also If the opener has safety sensors one or both of them may be burnt out too, and if it was really bad then the rpm sensor will go too. So you could be looking at paying half the cost to repair or just get a new opener. Up to you, and get a surge protector. Lift master has a good line of products and makes thier own surge protectors for thier products.
Jun 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Light flashing and control won't work
Jun 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
