Was wondering if valve needs to be cleaned out periodically or check to see if something lodged inside valve causing the noising water turbulence when pump running or is this just normal noise?
These valves will get stiff with time and grit and sand will get into the shaft of the valve and make it hard to turn. As far as the noise, the valve is probally an 1 1/2" valve. The volocity of the water through the valve will cause cavation and this noise. When you get to the point where you need a new valve you can fix this by using a 2" valve.
