Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Maytag MDB7600 issues
I have a Maytag Quiet Series 300 and it doesn't fill the tub with water. It had been working for sometime now it just displays the time for each cycle and does respond when I press start/cancel. When i press it a second time it responds with trying to drain the tub. Thoughts?
Rash
  • 1 more comment
  • mark548 Dec 05, 2008
    I have the same problem and the float thing did not help
  • Anonymous May 16, 2009
    I have a similar problem. I start the cycle then some water fills at the bottom of the d/w then it shuts off. Pressing the Start/Cancel button again drains the water.
    -Doug
  • Doug May 16, 2009
    President:
  • Maytag Master
  • 2,651 Answers
Reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Posted on Mar 20, 2008
How should I clean the Maytag Quiet Series 300 with vinegar?
just fill it with water no soap and drop in vinegar right in the water and let it run its cycle
Jan 27, 2015 | matag Maytag QuietSeries 300 Dishwasher...
Maytag bravos quiet series 300.. I washed a blanket and it literally disintegrated into millions of pieces. How I clean it out from the inside basket. I cleaned it out of the tub but I'm sure there are...
I would fill the tub with water,like i'm going to wash a load,but don't put in any clothes .Run the complete wash cycle and see if the water all drains out.
Jun 05, 2014 | Washing Machines
Maytag quiet series 300. fills up, runs, then shuts off early with water in the bottom. sometimes it shut off a minute after starting it.
You could have a problem with the door locking mechanism or the motor control board. You should have a tech check that out because if you purchase the parts and they dont fix the problem youll probably be out a small chunk of change.
Sep 16, 2009 | Maytag Dishwashers
Foul smell coming from Maytag Quiet Series 300
Hello jscott,
It is typical nowdays for most dishwashers not to drain all water out of the bottom tub (Even where you cant see) due to siphon design and energy efficiency. Try using about a liter of vinegar and throw it on the bottom tub of the dishwasher. Let it run through a full cycle and see how that works. Has worked for me
Sep 07, 2009 | Dishwashers
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
488 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
