Question about Kitchen Ranges
Kitchen Aid Gas Range, Model KGR 1801
Please HELP! My kitchen aid gas range is showing the following code in the control panel: F2EO in the upper right corner, and the words "Err" "stuck key" on the left side. I have unplugged the range for an hour then after plugging it back in the message returns. If I turn the range "off" then hit "start" the control panel asks me to "set the clock" but when I try the number pad doesn't work; then, I press "bake" and the oven turns on to "pre-heating" status for about 20 seconds before automatically shutting off and the F2EO code reappears.
I really appreciate any help you can provide, funds are very low right now and I have a long list of emergency items that need to be taken care of before this. Thank You so much for your assistance.
Sincerely, Roxane
  • 2 more comments
  • Anonymous Dec 13, 2008
    I have Model KGRA806PSSO which has the same problem
  • Anonymous Jan 04, 2009
    exact same error code on ours!
  • kaevans Jan 06, 2009
    Same problem--I've had it before a couple of times, and it's resolved on its own... eventually. I don't know whether it will this time or not. I think KitchenAid needs to fix this, as I see people with this problem all over the web...
  • robbinsclan Feb 02, 2009
    Add me to your list of stuck key Err F2EO
    Tried turning off breaker a couple of times to reset and it does nothing. Stove is less than 2 years old.Won't be buying Kitchenaid again.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) theres the bad news its reading a stuck key pad. replace the control..
there may be a good side and that is depending on age of machine they usually come with a 5 yr part warr on their electrical components, in which case youd only pay service and labor to install it
Posted on Mar 20, 2008
Kitchen aid gas range model kgsa906pss. After using self clean oven door is locked and control panel is out. There is power through the thermal fuse. What else should I check?
Try unplugging the unit for about 10 minutes and then plugging it back in. If the problem persists call for service especially if under warranty.
Apr 11, 2014 | KitchenAid KGSA906PSS Gas Kitchen Range
My kitchen aid gas range display F5:E3 and contact touch board has no function
Hi
Error code F5-E3 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen aid gas range igniters won't stop
Jammed and broken ignight switch or the spark generator transformer has a short circuit
Jul 13, 2011 | KitchenAid KGSK901SSS Gas Range
I need my kitchen aid oven to unlock
NEVER use the self cleaning feature - again!!
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | Whirlpool GS460 Gas Kitchen Range
We have a kitchen aid KGSA906PSS00 gas range. for the first time today the wife decided to run the self clean function. At some point through the self clean the oven shut off and the control panel died....
Jan 27, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Oven burner won't ignite
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 19, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Self cleaning attempt has shut down the control panel.
You need an air flow kit, part 81911788 and a professional to install it.
Dec 23, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Blown fuse inmy kitchen aid range
if you havnt lost your main input 120/240 voltage then check around the control panel,you'll probably find a special control fuse in this area
Jul 14, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Aid KGRC608
Hi does this range have a fuse for the circuit/timer board its not on at all but burners still lite and starter works if the is a fuse will you tell me where its at or is the top board fryed or the bottom board yes there is a bottom board on the right sie base in draw area dont know what to change i thought maybe it was only a fuse but can't locate it thanks for your help with this . model kgrc608lss0
Jul 30, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Ranges Logo
1,189 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
