My washer has been off balance for a little while tonight I put a load in and went back to check on it and there wa water pouring from the back left corner I have checked several DIY places and they say I need to remove the front of the washer any further advise?
  • Ron Coons
    Ron Coons May 11, 2010
    would need the make and model for proper diag
    Genius:
  • 1,554 Answers
It might have gotten so out of balance to slosh the water over the side , or to break the supply hose connector to the tub or pump.
either way you will likely have to open it to find out.
screws should be on bottom front to open it and clips on top sides.
generally.
Posted on Mar 20, 2008
Where does the fabric softener and washing powder go in the LG WF-F5207PC 5.5KG top loading washing machine?
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Feb 13, 2011 | LG Washing Machines
What is oL code?
ol code is for over load. Too many clothes. Sometimes you will get this code with nothing in the tub and the water keeps filling then goes to drain. if this is why your asking then pull the back off the washer and pull the clear tube off the tub. Blow in the tube and then the washer will take off and start operating correctly, Well till you stop blowing. This is a pressure problem and air is leaking right there at the tub and tube. I suggest a little plumbers dope and put the hose back on. if machine does not return to normal then you got a little dope in the air way. Pull the tube and replace again. Wa La!
Apr 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Washer Leak
Check the back of the tub as the water is coming in. Sometimes the water inlet gets knocked out of line if the machine shakes a lot or gets moved.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't drain completely
water sond when tub is spun by hand is normal. there will always be wa terinside machine betwen tubs, maytag even uses a waterfilled tub ring for counter balance, totlly normal to hear. as far as mildew smells, use www.affresh.com
Apr 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water in softener dispenser
the conditioner works by siphoning out when the water from filling mixes with it, the excess water then drains away the same way, when you took the drawer out, you must have either not cleared all the powder or not put it back together properly, if it worked before it has to be something you have done, sorry, just keep trying different ways and double check to see if all bits have been cleaned properly if i have helped please rate me
Sep 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking out of detergent dispenser- big time
Water pressure may be too high,try turning the cold water feed pipe (usually the blue one)down a little,not too much though.If this does not solve it,is the machine lying level front to back? If not pack up the front of washer until level.If still no good take out dispenser drawer completely check for obstruction inside housing of machine. Also while drawer is out clean the underside or top of dispenser housing with an old toothbrush or similar tool,(you will see several pin holes where the water comes out when filling).To take out dispenser open drawer fully and there should be a clip at top back of drawer that you push while pulling drawer at the same time.Hope this is useful to you.
Aug 24, 2007 | Haier XQG50-11 Front Load Washer / Dryer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
