I'm actually looking for the iLo brand not LG. I heard they are out of business. Thanks for the help tho.I'm actually looking for the iLo brand not LG. I heard they are out of business. Thanks for the help tho.
You can't post conmments that contain an email address.
Bad parts on your power supply board need testing and replacing....when you get the tv serviced be sure to tell the technician to install higher quality parts. ILO tends to use low-grade components that warp very quickly as their not designed to handle excessive heat for long periods of time. This is a very common problem with ILO and Akai tv's....
A universal remote will work. All you have to do is hit the imput button on the universal remote. Also you can contact... FUNAI CORPORATION Customer Service Tel :1-800-605-8453 http://www.funai-corp.com
You are also able to order a replacement remote thru them.
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
This is Fox Internationals # 800-321-6993 they are authorized parts distributor, Ilo will not talk or sell to you, Be sure to have model number in hand when you make the call. good luck with it :)
You may want to contact Funai. They are the company that makes the Ilo brand. Their parts department may be able to find the cable you need and order it for you. 800-242-7158 [email protected]
