Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile range oven door
The range oven glass door fell off. The door doesn't stay open. The glass door was glued on at the bottom and with heavy foil torn off??
Any suggestion?
  • jtlgol Mar 22, 2008
    I found the metal track at the bottom, it is not used to hold up the door. The door is glued onto the outside of the track like caulk.
    I tried to attached a picture here but it did not take 2.9MB. Do you have a email address?
I can lookup witha complete model number of the unit jgbp90 nt a complete number
Posted on Mar 23, 2008
    President:
  • GE Master
  • 2,651 Answers
Foil was just protective heat tape, there is a track across the bottom of door that is holding it up,
Posted on Mar 20, 2008
Ge profile self-Cleaning oven: how do I clean between the glass door. Where do I take t apart?
Hello Patricia
Oven doors by their design are very difficult, almost impossible to open then re-assemble. Not advised.
However, for the brave-hearted, oven doors can be open, eg to change a broken spring etc.
This involves dressing in protective gear as glass fiber wool insulation inside stove and door casing is very hazardous.
Strip half the stove to get to the hinge/arm mountings, unbolt so that door & hinge-arms come free, lay face-down on newspaper.
Using brute strength, unscrew Philips screws which have stuck solid from years of baked fat and heat.
Lift carerfully and try to avoid itchy glass fibres.
Glass inspection hatch insert may have stuck to silicone seal so press until it falls free.
Clean glass & re-assemble all in reverse order.
Trying to get the hinge-arms to line up while holding the heavy door is the most difficult part.
Can lead to stress, premature ageing....
Hope this helps :)
Clive.
Oct 29, 2017 | GE Kitchen Ranges
The front glass of the oven door fell off, didn't break....but, how do I put it back on? Was it just glued?
Hello. Notice in pic 2 of the exploded diagram of the door, part 359 which is the bottom door trim, part# WB07K0379. I believe this holds the glass in the door if I'm thinking of the right model oven. The glass door steel cover (designation 314) is WB57K10049. I'm not sure if your glass panel was glued to the steel cover--that's why I gave the part number for it--just in case it can't be repaired. If you need more info or part numbers, leave a comment and I'll be glad to help you further!
Sep 21, 2015 | GE Profile Spectra JGBP90 Gas Kitchen...
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
WHILE MAKING HOT CHOCOLATE THE OTHER DAY, THE MILK BOILED OVER AND SOME OF THE MILK WENT THREW THE SLITS AT THE TOP OF THE OVEN DOOR BETWEEN THE TWO GLASSES IN THE DOOR. IS THERE ANY WAY TO OPEN UP THE...
First, you will need a heavy blanket to place the door on once you have removed it from the oven. Open the door slightly, until it stays open by itself, about 15 degrees. Lift the oven door off of the hinges and place on the heavy blanket. (The hinges may snap shut when you pull the door up and off, but this is actually normal. It takes a bit of finesse to get the door back on the hinges if they will not stay out.)
Remove the 4 screws across the bottom of the door. Next, stand the door up with the bottom on the blanket and the front facing you.(Hold the door by gripping firmly around the middle edges to maneuver door)
Now, while holding the handle, remove the 2 screws that hold the handle on, unscrewing them just enough until the handle is free. (You do not want the spacers dropping off the screws) Hold the door together with one hand while placing the handle out of your way.
Once again, grab the door firmly by the middle outer edges and lie the door down, the inside facing down. You should be able to lift up the outer panel and glass and clean the inside of the outer glass.
Reverse the above procedure to reassembly the door. You can also take the door apart further if you have stains inside the other glasses. Here is a link to a schematic for your oven door.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0211500-00004.png
Apr 15, 2011 | Kenmore Ovens
Range door insulation strip
this white/silver strip I presume is the seperator between the inner and outer glass ? if so, you shouldreplace it and is so, use a little silicne caulk to keep it in place. it is tricky job to open the door inner and outer panels; you may want the hands of a second person. he strip keeps dirt from covering the inside of the glass panels and smoke film from bulding on the glass otherwise you will never see thru it. Goodluck, macgivor
Jan 26, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you change the oven bulb in a GE Profile Convection oven?
Unplug or flip breaker to the range. Remove wire around glass bulb protector by sliding one side out of clip while holding onto glass protector so it doesn't fall into the oven and break. Unscrew old bulb, replace with new one. Hold glass bulb protector over the bulb and hook wire back into its clip. Voila! Back in business. (I didn't unplug it, but discovered that you can't turn off the bulb, so it shines in your eyes while the oven door is open. Also, very stupid thing to do, since the bulb could very easily have broken in my very clumsy hand and given me a bad shock. So do it right, and unplug!)
Jun 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Still Heating with nothing selected
IS THIS A DIGITAL RANGE,IF SO REMOVE THE TOP BACK COVER AND SEE IF ANYTHING ARCED(BURNED SPOTS) ON THE CONTROL BOARD,IF NOT DIGITAL, YOUR OVEN KNOB SWITCH IS STUCK IN CLEAN MODE,I HOPE IT'S NOT THE CONTROL BOARD AS THEY RUN ABOUT $200 ,LET ME KNOW-MIKE
Jun 15, 2008 | GE JBP65 Electric Kitchen Range
theres a bottom trim that installs from under the doorwith 3 phillips screws, this is what holds the door in place. it probably rests under the hanndlesupport and is held up by this strip, take a close look at bottom of door and you see the removable metal strip..
Mar 20, 2008 | Hotpoint RB787 Electric Kitchen Range
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
355 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
