Question about Corona 23-DK Compact Heater
Two small tubular sleeves
I took the cage and main cabinet apart to get at the wick.. Two small metal sleeves fell on the floor. they are a zinc/brassy color and i don't know where they go for re-assembly. the owners manual doesn't mention them. thanks for the help.
The two sleeves go between the cage ends thus creating a "connection", and covering the ends of the two parts of the cage (stick the sleeves on one side, then insert the end on the other side of the cage).Make sense?
Posted on Aug 02, 2008
I took it apart to get a staple out. two small metal bracets with a u shaped center fell out where do they go
Most likely at both sides of the main shaft to keep it centered in the housing. You will see two slots in the cover where they slide in.
Jan 01, 2016 | Office Equipment & Supplies
Small water leak on floor on both sides of door. w ater is not coming from refrigerator or bottom freezer unit
Did you notice any moisture on the main cabinet at the area the doors seal against? Some models have a heater imbedded in the cabinet edge at the door seal to keep the metal cabinet from sweating much like a glass does when filled with water and ice cubes. If the heater is not on the metal sweats and leaks down to the floor. Some refrigerators have an option switch called and energy saver that can turn that heater on or off. Off is OK for winter but needs to be on in humid weather if house is not air conditioned. Heater could also be burned out (bad).
Apr 30, 2015 | Maytag Refrigerators
My keyless entry for my 07 Honda Civic dry roted and fell apart. A security feature is it won't crank. if the metal and plastic aren't together. I ordered a new empty shell but when I opened the old one...
This is a common problem on key-less entry control unis. They are very cheaply made, in time the contacts the hold the button battery in place get loose from the PC board because the solder joints fail On some models there's is a small spring that transfers power from one side of the board to the other, the spring may have fallen out when you took it apart so the power will only be on one side. look very closely inside the shells of the old one you should be able to see a small round wear spot someplace and a corresponding small hole etc on the other half of the shell, if you find them the small spring is missing. Use any metal spring that fits and snip it to the right height, then assmble and it should work, providing your battery(s) is good.
Aug 11, 2014 | Cars & Trucks
Marcy Upright Fan Cycle - Fan Hitting Cage As It Spins
You did great with the assembly, however, you're off on the alignment. Try to adjust to pull the axle in the opposite direction to clear the cage.
Nov 11, 2013 | MARCY MCPL 105 Upright Fan Bike
Bike starts and runs ok but wont rev out .Thanks in advance
check the air filter is not obstructed or dirty. if thats ok then it is more than likely the carbs that need attention/resetting/cleaning out
Mar 15, 2011 | 1989 Yamaha Xv 250 Virago S
Have a Dyna-Glo. Took it apart to change the wick
take the wick back out lower your nob and install wick, I hope this help you, I have made this mistake too
Oct 23, 2009 | Corona 23-DK Compact Heater
How do i change the wick?
You need a pair of Pliers, a flat-tip screwdriver and a plastic bag (for old wick)
ALSO - make sure the tank is empty (or as close as possible)
1. Turn the control knob to OFF.
2. On the left and right side (bottom, just under the wire cage are two cabinet screws. Remove these.
3. Using the handle, lift straight up to remove the cabinet (entire upper assembly)
4. Gently pull off the wick adjustment knob (you will need to push in the little square button.
5. Remove the "dressing plate" (the ring about 3" high) that the "Off" "Low" and "High" markings. The chain attaches this the fuel cap, but you don't have to remove the cap. Just set the "dress plate" ring aside as far as the chain lets you.
6. Either trip the manual shut-off or push against the wobbly pendulum to the left of the control knob shaft to drop the wick all the way down.
7. Remove the four wing nuts that holds the heater on the wick assembly and carefilly lift teh sick assembly from the heater.
8. Reset the automatic shut-off, put the know back on temporarily and raise the wick all the way.
9. Turn the Wick Assembly upside down. Place the white plastic strip, packed with the new Wick, on the Wick Cover to protect your fingers.
10. While holding the Wick Assembly upside down, pull off the Wick Cover with a sharp tug.
11. Remove the Wick while folding it to the inside. (Remove the Wick Sleeve together with the Wick).
12. Take the new wick and insert the Wick pins into the three holes of the Wick Sleeve. (Make sure the short portion of the Wick is UP.)
13. Attach the Wick wo the retainer teeth of the Wick Sleeve stick into it, making sure the Wick fits evenly arount the inside with no wrinkles or bunching.
14. Fit the Wick and Wick Sleeve back onto the Wick Guide, making sure you fit the pins through the slanted grooves of the Wick Guide and Press on each of the three pins from the back, making sure they are inserted securely through the holes on the Wick Guide. (This is where most people screw up Wick Replacement, so make sure you get this right)
15. Turn the Wick Adjustment Knob to make sure the Wick slides up and down freely. (Note, the wick should automatically be set to 3/8 of an inch when fully raised.)
16. Turn the Wick Assembly upside down and replace the Wick Cover by: Align the four tabs on teh Wick Cover with the four screw holes on the bottom of teh assembly and snap it into place.
17. Hold the Set Lever to down position with your finger.
18. Remove the protective strips from the Wick Cover. Turn the Wick Adjustment Knob to the fully raised position and light pull on the "skirt" of the Wick to remove any slack. Then press the skirt lightly onto the teeth on the Wick Cover to hold it in place.
19. Replace the Wick Assembly on the heater WITH THE WICK RAISED. Replace the wing nuts, tightening gradually, tightening opposites sides first(If counting clockwise, tighten screw 1, 3, 4, 2 - go through several rounds, tightening gradually so it seats evenly
20. Before further reassembly, trip the Auto shut-off and reset it to make sure it works properly. Test the Wick adjustment knob to make sure Wick slides up AND down freely.
21. Remove the knob and replace the "dressing plate ring.
22. Replace the entire upper assembly "Heater Cabinet" and repalce the two screws. Replace the Wick Adjustment Knob.
Oct 11, 2009 | Corona 23-DK Compact Heater
Corona 23-DK wick replacement
yes the sleeve comes out and ther should be a couple little barbs holding the old wick in.fold the new wick to put it in making sure the adjustment pin is in the right place on the sleeve then slide the whole thing back in making sure to get the adjustment pin into the nob while sliding the sleeve an wick down
Dec 27, 2008 | Corona 23-DK Compact Heater
Corona 23-DK Compact Heater Logo
51 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
