Question about Panasonic KX TC280B Cordless Phone (KX-TC280-B)
No lIne sound and make others extension phone busy sound when calling
My Tc-280 got some problem, I had other extension phone on the same line, when calling income will become busy sound ,when I disconnect tc-280 from lines the other phone is back normal , and TC-280 got heavy noisy , I doubt the circuit got some problem, can anyone help to repair it ? Many thanks.
    Problem Solver:
  • 11 Answers
To prove circuit is okay you need to swap phones
It probably is the phone extension line (from the wall)
to the phone.
Again you need to test phones using a known working phone cord. When you rule out the circuit and line cord then you can only point to the phone itself or the demarc point.
GL
Posted on Mar 20, 2008
SOURCE:
Why made phone early now cant just get busy signals?
Sounds like your phone or line is now short circuit and is holding the line so it appears busy to incoming callers. Try disconnecting the pnone and line right up to the incoming point of your house to find the problem.
Jul 30, 2014 | AT&T CRL82312 3 Handset Answering System...
I have put a main greeting on my Norstar M7310 phone for all 5 incoming lines, however one of our incoming lines has grabbed a personal message form another extension and callers get that personal message...
You need to know what extension is causing the forward directly to voice mail. Chances are that this extension has ringing lines programmed to it and the forward on busy is to voice mail. ANY PHONE THAT HAS RINGING LINES SHOULD NOT BE SET TO FORWARD ON BUSY. If they happen to be on the phone when a call comes in it will go straight to their personal mailbox.
Aug 09, 2013 | NorStar M7310 Phone
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Group Pickup setup on Strata 280 phone system
Try Googling (Toshiba)(280)(manual) without parens.
Aug 12, 2017 | Toshiba Computers & Internet
During incoming call the line will go to others extension line.
Consult an expert he will fix it bcos normally they wont let go their codes.
Rate this
Apr 06, 2009 | Panasonic KX-T7730 Corded Phone
Tc not work in my pc
Hi Shashi,
please make sure the TC files are extracted in following folders after installation
c:\tc\bin --> all executable files
c:\\tc\include --> all header files with .h extension
c:\tc\lib --> all library files
c:\tc\obj --> all .obj files copy them to c:\tc\bin too
now goto my computer --> c:\tc\bin
copy tc.exe file and right click on desktop and select copy short cut and press enter
Now you can start TC simply doubleclicking this shortcut icon
Please call if having any problem
Zulfikar Ali
[email protected]
09899780221
Mar 14, 2009 | Microsoft Windows XP Professional With...
Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Aug 08, 2008 | Panasonic KX-T7630 Corded Phone
Transfering calls
It sounds like your dealer didn't properly set up incoming call distribution groups. They probably just gave you the "default" settings and left you a manual, took the check and said, "Good bye, and good luck!"
I think you mean transfer instead of forward. Your incoming calls should go through an Incoming Call Group - even if you're the only person in the group. Then you can handle the calls as they come in, transfer them out, and if you run out of buttons the system can even queue the calls up until you can get to them.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Jul 09, 2008 | Panasonic KX-T7633 Corded Phone
NEC phone system - Forwarding incoming call gets busy signal
please call the engineer from which you have purchased the EPBAX system to congiure the same. It happens if something is wrong in line card at the exchange or the extentions are not configured properly with the Key Telephone System.
Apr 18, 2008 | Lands Phones
Panasonic KX TC280B Cordless Phone (KX-TC280-B) Logo
187 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
