Question about Canon I990 InkJet Photo Printer
Cannon IP1880 Cannot detect Cartridge
I have Canon PIXMA IP1880 before working correctly using Genuine Canon Cartridge but when I try to insert my CIS cartridge an error shows :
"The function for detecting the ink will be disable
since the ink level cannot b detected
canon recommends to use new genuine canon cartridge in order to obtain optimum qualities."
but when I insert again my old (Previousely use and working) Genuine Canon cartridge same error display. Kindly help me solved this Problem.
Thanks...
  • 5 more comments
  • benjamin ramos Apr 04, 2008
    Yes, I have the same problem. When I tried to refill the cartridge and insert it again into my printer but it did not recognized or won't accept the cartridge.
    What seem's to be the problem.....
    Benjie
  • Argion Dadulla Apr 28, 2008
    I updated the driver, Cleaned the interior, installed new and old cartridge, but still cannot detect. My printer worked just yesterday. :(
  • Anonymous Sep 05, 2008
    I have the same problem with iP1300 using PG40 and CL41 cartridges. error was 7 blinking orange light and 1 green light. Not printing and printer tells color cartridge not being recognized. even installing a brand new color cartridge the problem is the same . help...
    benjie
  • Anonymous Sep 29, 2008
    I'm getting the same error message when trying to print. I only have black cartridge because I already disposed the old ones. Does it have to be with the colored cartidge for it to work?
  • myminiheart Mar 20, 2009
    i have the same problem with my pixman ip1880 printer. I used a new ink compatible to the printer when i try to print the it said the ink in not compatible and the orange light keep on blinking
  • juvinramirez May 19, 2009
    My printer cannot recognize the black and color cartridges. Why is this so and how can I repair this to normal?
  • Anonymous Mar 12, 2014
    Dear All
    I disabled ink level detection for Canon IPF8000S and IPF8100, and now I want to enable them. Someone can help me and i had no service manual. thank you very much.
    From Sengdy, Cambodia
Press the resume button 5seconds(this disable ink cartridge monitor..
Posted on May 12, 2008
  • dylanandme04
    dylanandme04 May 09, 2014
    what resume button ?
I have Canon PIXMA IP1880 before working correctly using Genuine Canon Cartridge but when I try to insert my CIS cartridge an error shows : "The function for detecting the ink will be disable since the ink level cannot b detected canon recommends to use new genuine canon...
Posted on Nov 21, 2008
Thx! man
Posted on Sep 29, 2008
    Genius:
  • 3,587 Answers
Hmmm..well..you may find that new drivers help a bit.
get them here
Posted on Mar 20, 2008
  • jeei Oct 23, 2010
    your link is broken
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon ip1800 printer won't print.
My Canon PIXMA iP1880 cannot print...and shows a message "ink absorber is full" can u help me this problem..
Mar 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon mp160 error
E5 means one of three things.
1. The ink cartridges are not installed
2. The ink cartridges installed are not compatible
3. The ink cartridges are not installed correctly.
Are you using genuine Canon or a copy cartridge? If copy then they may not be correct. If they are genuine Canon you may need a new printhead.
Nov 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
PIXMA iP1880 ink cartridge not properly installed....
one solution is turn off your printer, and reboot your system, after rebooting, turn on your printer again. If that doesn't work try re-installing the printer drivers be sure to turn off the printer and reboot the system afterwards to refresh the system.
Hope this was helpful:)
Oct 19, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
CANON IP 1880
i need install canon ip1880.. how?
Mar 21, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
IP1880 Canon PIXMA showing Ink absorber full
Pixma ip 1880 is full(solution)
1. first unplug power cable and usb cable
2. hold power for 1-2 minutes
3. turn on power
4. your printer should back to normal printing
Mar 07, 2008 | Canon I990 InkJet Photo Printer
Refilling canon iP 1880 color cartridge
Insert a fine needle through the hole and when the ink sticks to the needle withdraw it and rub on a white cloth and identify the color and mark the holes accordingly.
Jan 23, 2008 | Canon PIXMA iP1600 Printer
Canon I990 InkJet Photo Printer Logo
6,389 people viewed this question
old marine
old marine
